belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
53 registered members (Bailes1992, aleneros, berlyn, 928, bbhero, Arob, 6 invisible), 1,428 guests, and 22 spiders.
Topics301,895
Posts5,204,845
Members70,798
Page 1 of 4 1 2 3 4
Oil for vintage Mopars #5191430 08/19/19 03:37 PM
4
440Magnum Offline OP
4
Hello, BITOG... I used to be a frequent poster/reader on here, but I've been pretty inactive for a few years and am a bit out of the loop on the current state of oils. Cutting to my question:
What's the current recommendation for a good, solid Xw40 or thickish Xw30 oil for a couple of stock(ish), non-raced, well-broken-in but very clean internally Mopar 440s with reproduction "Magnum/Commando/Roadrunner" hydraulic flat tappet cams, and stock valve springs?
A little more detail: Both of these engines ran on Rotella T6 5w40 for 10-15 years, and I had no complaints. I'm not one to go into a big panic over reduced ZDDP levels on basically stock engines, but the changes in API oils, including RT6, gave me a little pause. I searched on here for a recent VOA of the newest version, but found nothing other than a lot of chatter about "Rotella Gas Truck" oil, which is definitely NOT the right direction. So I'm just kinda looking at options. I ran an OCI of Royal Purple HPS in all of my cars, and I actually noticed a fairly significant jump in consumption, not just on the two weekend-driven 440s, but on my (now well out of warranty) SRT-8 392. So probably no more RP for me. The SRT will probably just go back to M1 0w40, but I'm undecided on the 440s.
So... is RT6 still a good option? Amzoil Z-rod (only available in 10w30 or 20w50)? Redline? If so, which one? Expense isn't an issue, really, since these cars rarely get more than one oil change a year, if that. I'm not really willing to go crazy with the trendier race oils like Driven. I 'd rather stick to the big refiners and blenders, or at least older boutique blenders like Amsoil or Redline. I would even consider sticking with RP HPS since I know its got a decent additive package, but I'm really disappointed that all the poor NOACK tests I've seen really seem to be reflected in my real-world experience.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Oil for vintage Mopars [Re: 440Magnum] #5191437 08/19/19 03:47 PM
skyactiv Offline
I'd use a full-saps 5W40 Euro oil stating BMW LL01 on it. A BMW LL01 0W40 would work well, too, even though it isn't needed in Texas.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Oil for vintage Mopars [Re: 440Magnum] #5191438 08/19/19 03:50 PM
R
Rob_Roy Offline
R
Any 15w-40 HDEO will work fine in that application. No need for a synthetic.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Oil for vintage Mopars [Re: Rob_Roy] #5191445 08/19/19 04:00 PM
4
4
Not needed... they lived for decades on Group II oils before I had them, after all. But after all the work I've done and the current state of the art, they're going to get synthetics anyway. No reason not to given the infrequent changes.
Re: Oil for vintage Mopars [Re: 440Magnum] #5191461 08/19/19 04:17 PM
SR5 Offline
Keep going with the Rotella T6 5W40, they have changed the formula but it still has ample ZDDP and it passes better wear tests than before. I found these zinc values in the VOA / UOA section here
Rotella T6 5W40
CJ4 ~ 1390 ppm
CK4 ~ 1199 ppm
A typical ILSAC GF-5 oil would have about 750 ppm Zn, and Euro A3/B4 oils typically have about 1000 ppm zinc.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Oil for vintage Mopars [Re: 440Magnum] #5191463 08/19/19 04:20 PM
J
JeffKeryk Offline
J
I am running Rotella T in our '68 L36 Vette and '65 4-4-2, both really original.
If I ever pull those mills apart again I am gonna stab a mild hyd roller.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Oil for vintage Mopars [Re: SR5] #5191469 08/19/19 04:22 PM
4
4
Rotella T6 5W40
CJ4 ~ 1390 ppm
CK4 ~ 1199 ppm
So the CK4 is the current production version, correct? If so, that's about all I needed to hear. Thanks, and I guess I *still* can't wring maximum effect out of the search engine on this board... :-p
Re: Oil for vintage Mopars [Re: 440Magnum] #5191470 08/19/19 04:22 PM
K
ka9mnx Offline
K
Mobil1 HM 10w-30 would be a good choice with an HTHS of 3.5, ACEA A3/B3 (high SAP) and it's on the thick side. I'm not familiar with M1 0w-40 but others have recommended it. All available from WalMart. I just switched my flat tappet F150 from years of M1 HM 10w-30 to SuperTech syn 5w-30 for a try. Engine runs smoother, quieter and peppier. I'm not recommending it for your 440 but I may stay with it.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Oil for vintage Mopars [Re: 440Magnum] #5191472 08/19/19 04:24 PM
BeerCan Offline
I used either Vavoline 15w40 or 5w40 hdeo in mine when I had it
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: Oil for vintage Mopars [Re: 440Magnum] #5191473 08/19/19 04:25 PM
B
bullwinkle Offline
B
I would be jumping all over that Joe Gibbs Driven HR 10W30 that is apparently under $30/case at Amazon!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Oil for vintage Mopars [Re: bullwinkle] #5191493 08/19/19 04:48 PM
R
Randy_R Offline
R
Ditto on Driven 10W-30 on Amazon $28.63/case. You have to dig a little. It’s listed more than once at a higher price. Says it won’t ship right away but it’s Amazon, not a third party. It’s conventional oil but I’m sure it will work depending on how often you change it.
2018 Mazda CX-5 6600 miles Zepro advanced moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 65,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 K&N
Re: Oil for vintage Mopars [Re: 440Magnum] #5191496 08/19/19 04:49 PM
R
ragtoplvr Offline
R
I also like any conventional motorcycle oil.
Rod
Re: Oil for vintage Mopars [Re: 440Magnum] #5191504 08/19/19 05:02 PM
sloinker Offline
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Oil for vintage Mopars [Re: Randy_R] #5191528 08/19/19 05:27 PM
R
Randy_R Offline
R
Not pushing Driven but there is another thread with a link to the Amazin listing in active threads.
Re: Oil for vintage Mopars [Re: 440Magnum] #5191545 08/19/19 05:42 PM
SR5 Offline
Rotella T6 5W40
CJ4 ~ 1390 ppm
CK4 ~ 1199 ppm
This is the VOA link you are after
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4490450/
Yes CK4 is the new stuff
Page 1 of 4 1 2 3 4
