Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
78 registered members (bbhero, bdcardinal, apollo18, ammolab, 7 invisible), 1,677 guests, and 21 spiders.
Topics301,894
Posts5,204,815
Members70,798
Noisy idle in gear but not neutral or park #5191314 08/19/19 01:30 PM
cwilliamsws6 Offline OP
I've noticed this a lot with my car lately especially when waiting at a red light or drive-thru for example.
If I am idling in gear with my foot on the brake it sounds like the engine is about to blow up but it smooths right out and sounds perfectly fine if I throw it into neutral or just park it. I checked the transmission fluid level and everything else while I was in there, everything was where it should be.
Video of the sound, ignore the SnapChat caption because I took the video before I realized the sound goes away if I put it out of gear:
https://www.youtube.com/watch?v=n7YeL3Phep4
Again, it only sounds like this if I idle in gear with my foot on the brake, but sounds normal if out of gear.
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: Noisy idle in gear but not neutral or park [Re: cwilliamsws6] #5191320 08/19/19 01:37 PM
L
Lolvoguy Offline
L
Motor/trans mounts?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Noisy idle in gear but not neutral or park [Re: Lolvoguy] #5191359 08/19/19 02:02 PM
U
user52165 Online Content
Online Content
U
Originally Posted by Lolvoguy
Motor/trans mounts?
+1 this
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy. It's inherent virtue is the equal sharing of misery.
Winston Churchill.
Re: Noisy idle in gear but not neutral or park [Re: cwilliamsws6] #5191363 08/19/19 02:06 PM
scurvy Offline
Heat shield rattling, combined with motor or transmission mounts that are weak.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Shell Rotella T6 5w40, HU726/2x, EaBP90
12 Mazda 5: Castrol Edge 0w20, FL910s
Re: Noisy idle in gear but not neutral or park [Re: cwilliamsws6] #5191371 08/19/19 02:16 PM
Get a Honda, they said.
They're reliable and low-maintenance, they said.
I don't have the tools to change them myself or the time since I'm back in school now.
Here goes another paycheck. smirk2
Re: Noisy idle in gear but not neutral or park [Re: cwilliamsws6] #5191378 08/19/19 02:23 PM
M
mk378 Online Content
Online Content
M
That's just a heat shield rattling. Also there could be an exhaust leak.
It gets worse in drive because that puts some strain on the drivetrain, the car is trying to move forward except you're holding the brake.
If you open the hood and either peek through the gap or have someone else drive, hold the brake on firmly and shift back and forth between drive and reverse. See how much the engine jumps around and what other noises you hear. Bad mounts will have it moving around a lot.
Re: Noisy idle in gear but not neutral or park [Re: cwilliamsws6] #5191600 08/19/19 06:50 PM
U
Online Content
U
210K miles! A maintenance item.
Sounds like the internals are good.
Small potatoes compared to engine/trans
Winston Churchill.
