36 registered members (carlprop, Alex_Cocco, bdcardinal, clinebarger, Bert_c, Bailes1992, 5 invisible),
880
guests, and 19
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,818
Posts5,141,856
Members70,129
Most Online3,589 Nov 2nd, 2019
L5P Duramax UOA #3
#5190991
08/19/19 05:42 AM
oakaro68
OP
OP
Posts: 44 |
Hey everyone,
This is my 3rd sample for this truck from Blackstone labs. 39,451mi on truck and 5,275mi on Shell Rotella T4 15w40. UOA came back really nice, although my Regen cycles increased in frequency using this particular oil. That I did not care for. I switched to T6 5w40 and have already noticed more distance between Regens along with a more stable/consistent/predictable soot reading when all things stayed pretty consistent (fuel refill station, driving habits, temperature, etc).
Re: L5P Duramax UOA #3
[Re: oakaro68]
#5191726
08/19/19 10:33 PM
BlakeB
Posts: 318 |
You might want to edit your personal info out of the report.
[Re: oakaro68]
#5192632
08/21/19 04:35 AM
oakaro68
OP
OP
Posts: 44 |
Having a hard time editing this post. Here's the sample
[Re: BlakeB]
#5192633
08/21/19 04:36 AM
oakaro68
OP
OP
Posts: 44 |
You might want to edit your personal info out of the report. Thanks BlakeB, totally spaced on that one. Good catch.
[Re: oakaro68]
#5192859
08/21/19 10:27 AM
dnewton3
Global Moderator
Global Moderator
Posts: 8,299 |
Looks perfectly fine; as do just about all Dmax UOAs. Stretch out the OCI and get some value from that oil.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters. - under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan - over maintaining something has never been proven to be anything but a waste of time and money
[Re: oakaro68]
#5193454
08/21/19 10:41 PM
BlakeB
Posts: 318 |
GM put out a bulletin for the 2019 L5P recommending a 7,500 mile, 300 hours or once per year oil change after some people were reporting that their OLM was counting down too quickly. My 2017 is well over 300 hours and still shows 28% on the OLM. My dad’s LML routinely goes ~500 hours between oil changes following the OLM. We both make daily short trips of less than a mile where the engine doesn’t get up to operating temperature, but the OLM doesn’t seem to care.
[Re: oakaro68]
#5193540
08/22/19 03:51 AM
dnewton3
Global Moderator
Global Moderator
Posts: 8,299 |
Well it's under warranty, so I get the concern ... But the data is telling you that the wear rates are really low for all metals; that's typical of a Dmax. There's no contamination to speak of. Longer OCIs are certainly a doable thing. After all, you're paying for the data. Don't ignore it. If you choose not to alter your OFCI plan (extending out), then I'd recommend you quit doing the UOAs. No sense spending money on data you're not going to use. After all, it's not like Dmax engines are known to grenade from normal use.
