Originally Posted by GoldDot40
Just a little fun FYI, when the EPA went to E10 and higher product, the fuel transport industry had to change the material the transfer hoses and gasket material to something rated for use with ethanol. The service life of the original hoses and gaskets was cut by almost 60% when E10 was mandated.
Another fun FYI...
In 2011, Mercury Marine conducted a study done using E15 and ethanol free gas in marine applications. It was a 300 hour endurance test. They used 2 identical pairs of different size outboard marine engines. The only difference was the gas used in each engine.
The 2 engines running E15 failed catastrophically before the tests were even completed. The 2 running non-ethanol fuel not only passed the endurance tests with flying colors, but upon a tear down inspection, there was nearly zero wear found in either of the 2 engines.
That's exactly why I run ethanol free gas in my boat.
The good news is that I tested my local Shell regular 87 octane gas last week and it showed about 5% ethanol. I run Shell about 90% of the time in my vehicles. More good news. My Mercedes sits for weeks at a time, with ethanol in the gas tank and fuel lines. It has done that since new. It appears to have suffered no issues.
Another fun FYI...
