It raises the boiling point of the coolant. IMO there is no reason to have more than 13psi on a street car. Especially an import with an aluminum head. So it won't boil till 267F but the head gaskets let go @245F.
Rather odd advice to ignore what your vehicle calls with a blanket 13 is all you need. My crown vic oem is 16 my old deville was 16psi prev owner had a 12 gauge stayed in the norm. Yet put coolant out the overflow. Proper cap called for installed and missing coolant ended. Non oem thermostats sometimes don't have the jiggler valve which can get air trapped and cause problems.
Originally Posted by WyrTwister
Use the temp / pressure rating that came ii it when it left the factory .
Do not worry about it .
🎯🎯🎯.. have replaced many caps over the years on various rides and have always went with the OE rating.
You start messing around with the pressure and you could have issues with that radiator... it's just not worth it.
