Originally Posted by Vern_in_IL
I think it does, I use my wipers everyday, and so far they work good. They don't get "stuck" on one side, and it prevents the buildup of dirt on the blade, if you never use your wipers except for rain, then they are stuck in one direction and dirt builds up and eats them on next use.
We're of the same mind. Yes the rubber blade pivots on a central spline and if you leave the blade parked with the blades retracting into park position all the time the
blade will take a set over some time, it doesn't take that long either. It's harder to do on new cars, but on older cars I would plip the wiper stalk and have the blades parked on the rise one time and then the next on the descent to keep that blade front setting one way, which causes chattering and juddering.
