Originally Posted by emmett442
The side with the PCV valve is always darker because the air flowing through that valve cover has picked up all of the gasses and contaminants. The air flowing through the opposite side is the fresh, filtered air from the air intake, so that side never gets stained.
I have to find the pictures again. Based on what you are saying, the pcv side should be darker! it kind of makes sense ...
My original post is incorrect then. Just remember seeing the pics and one side looked real bad.
Do the contaminants stain or leave a residue/sludge by condensing over the internal parts? Is it mostly cosmetic or can it form sludge?
I assume if it was causing long term problems to one side of an engine, they would have designed a dual pcv to distribute the deposits evenly.
