New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
107 registered members (2009Caraman, AC1DD, 55hambone, ammolab, 2010Civic, 13 invisible), 1,974 guests, and 18 spiders.
Topics301,806
Posts5,203,074
Members70,784
2018 Camry Transmission Drain & Refill Procedure #5190736 08/18/19 08:11 PM
P
painfx Offline OP
P
Does anyone know the procedure on how to drain and refill the 8 speed automatic transmission?
Re: 2018 Camry Transmission Drain & Refill Procedure [Re: painfx] #5190759 08/18/19 08:36 PM
saginawmale50 Offline
drive to the dealer and write a check
Re: 2018 Camry Transmission Drain & Refill Procedure [Re: painfx] #5190773 08/18/19 08:56 PM
P
parshisa Online Content
Online Content
P
https://www.youtube.com/watch?v=tbmAQG5J1pA
Here's the youtube video. it is in russian but very detailed and quite good as far as steps to follow
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: 2018 Camry Transmission Drain & Refill Procedure [Re: painfx] #5190867 08/18/19 11:53 PM
The Critic Offline
It was in the document I gave you...
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: 2018 Camry Transmission Drain & Refill Procedure [Re: painfx] #5191018 08/19/19 06:09 AM
L
LotI Offline
L
It has the same standpipe/drain plug that Aisin have been using for years. Lots of videos and instructions. There are two fill plugs on top, pick which one is easier to get to.
You need to replace the drain plug with one that has an o-ring as the factory fitment doesn’t use one. When filling, you need to monitor trans fluid temperature to get the right fill level.
This should keep you busy for an hour:
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
