Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
94 registered members (2strokeNorthstar, AC1DD, 01VFR, 2013ecof150, 4WD, 2010Civic, 12 invisible), 1,673 guests, and 17 spiders.
Topics301,808
Posts5,203,104
Members70,784
Is it worth using a dehumidifier to help cool house? #5190715 08/18/19 07:47 PM
G
gregk24 Online Content OP
OP Online Content
G
Our A/C seems to struggle to cool off our house, especially in the summer. I am not sure what size the unit is, but I do know the condenser was replaced after 2013. I am looking into purchasing a dehumidifier to remove excess moisture from the house. I am borrowing my mother in law's unit for a week or so to see if it helps. Do any of you use one of these to help remove excess moisture and make your house more comfortable? Also, I will be checking my energy use to see if it will reduce our bill.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190719 08/18/19 07:50 PM
E
eljefino Online Content
Online Content
E
Get your house AC tuned up better. Dehumidifiers leave you with warm air and a bucket of water.
Re: Is it worth using a dehumidifier to help cool house? [Re: eljefino] #5190731 08/18/19 08:03 PM
R
Rmay635703 Offline
R
Some of the older less efficient AC units are just as capable of dehumidifying as an actual dehumidifier.
A dehumidifier makes about 300-500% more heat than it uses in Watts so expect things to get toasty,
Dehumidifiers are great in the winter and perfect if you have a floor drain and lots of vacation to stay out of the house.
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190741 08/18/19 08:18 PM
dishdude Online Content
Online Content
How's the duct work and insulation?
In a humid environment like FL, a dehumidifier isn't a bad idea. Do you have a hygrometer to see if it's needed?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Is it worth using a dehumidifier to help cool house? [Re: dishdude] #5190758 08/18/19 08:35 PM
G
OP Online Content
G
We live in a 1959 home, ductwork is original as far as I know and insulation is only blown in in the attic.
60,xxx miles
54,xxx miles
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190760 08/18/19 08:38 PM
Online Content
For the duct work you can see, is it sealed with mastic? is the insulation deep enough? How's ventilation in the attic? A fan up there might be a consideration.
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190785 08/18/19 09:08 PM
A
Alfred_B Offline
A
I would use a portable AC for additional cooling. Some have a dry function as well.
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190812 08/18/19 09:42 PM
Nick1994 Offline
Try to gather some numbers.
Outside temp, inside temp set to, actual temp inside house at hottest part of day, humidity *(in and out), etc. Then put your thermometer for an hour or so in each room, any rooms warmer than others?
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Is it worth using a dehumidifier to help cool house? [Re: Alfred_B] #5190833 08/18/19 10:18 PM
G
Gillsy Offline
G
Portables in my opinion won't help. All that hot air that the portables blow outside is replaced with outside air being drawn back into the house or you would wind up with a vacuum. They in my situation raise the humidity in the house, and I verify that with a hygrometer. If the condenser is too big, it may short cycle, and not run long enough to remove the humidity. If too small, it can't remove enough humidity no matter how long it cycles. I'm no HVAC pro, but maybe someone with more know-how can chime in.
Many are the afflictions of a righteous man
2019 Nissan Murano S
2018 Gravely ZT HD 52
2016 Kawasaki 650 Versys LT
2012 Mazda 3 Skyactiv 2 ltr
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190846 08/18/19 10:41 PM
M
mcrn Offline
M
2012 Nissan Rogue
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190849 08/18/19 10:44 PM
M
mcrn Offline
M
I use damp rid around my older house in Florida during summer.
2012 Nissan Rogue
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190976 08/19/19 05:25 AM
V
Virtus_Probi Offline
V
We have a vacation condo up in the mountains and externally visible AC units are not allowed, so on the occasional warm day we just run a dehumidifier in the place and it helps a lot.
The place was just a little toasty and close last time we went up there and it was quite comfortable after the dehumidifier had run for about an hour.
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5190980 08/19/19 05:28 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
A dehumidifier will never cool a house. It will always add heat. But it will make it more comfortable by reducing humidity.
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5191003 08/19/19 05:56 AM
skyactiv Offline
I would see if your gas or electric provider offers a free energy audit Many offer a free one.
Your home was built in 1959 when builders didn't care much about insulating as utilities were cheap.
There might be a tax credit if you have any work done.
You can rent a machine to blow it in from Home Depot... Make sure it's done correctly as you don't wanna cutoff air flow from any soffit vents.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Is it worth using a dehumidifier to help cool house? [Re: gregk24] #5191007 08/19/19 05:58 AM
AZjeff Online Content
Online Content
I think Greg's question is will lower humidity air cool better? Another question is will the old AC overcome the added heat from the dehumidifier when it's struggling already?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
