Is it worth its weight in cast iron?
by spavel6 - 07/06/20 03:42 PM
Hyundai O.E.M. 28113-H8100 replacement
by odie - 07/06/20 03:22 PM
Valvoline SynPower Power Steering Fluid
by Cheezit - 07/06/20 03:17 PM
Shell Rotella Gas Truck or Pennzoil?
by DCMotorsports - 07/06/20 02:49 PM
Interesting domino game
by 53' Stude - 07/06/20 02:49 PM
Grinding brakes when hot
by mclasser - 07/06/20 02:41 PM
Nylon spacers
by VeeDubb - 07/06/20 02:37 PM
Extra Long Valve Caps
by Mr_Luke - 07/06/20 02:28 PM
using vinegar to flush cooling system
by old1 - 07/06/20 02:11 PM
Best lube for refrigerator door hinges?
by paulri - 07/06/20 01:11 PM
RIP Ennio Morricone
by 2015_PSD - 07/06/20 12:49 PM
What oil do you recommend?
by BretBouer - 07/06/20 12:36 PM
NAPA Synthetic / Filter Sale
by WyrTwister - 07/06/20 12:16 PM
Squished Stihl MS 181
by Gebo - 07/06/20 12:14 PM
Used Review- '17 Nissan Armada Platinum
by panthermike - 07/06/20 11:53 AM
RIP Charlie Daniels.
by PimTac - 07/06/20 11:34 AM
Transmission fluid change
by dan765 - 07/06/20 10:53 AM
Toyota LL or SLL in a Ford?????
by TacoFergie - 07/06/20 10:52 AM
Pulling a vacuum to remove water
by Donald - 07/06/20 10:42 AM
Colt_38, DCMotorsports, BryceMateo, Dodgerose, AnotherPerson
71862 Registered Users
109 registered members (53' Stude, 4WD, 2015_PSD, 928, 97prizm, 77GrandPrix, 9 invisible), 2,338 guests, and 20 spiders.
Topics307,502
Posts5,312,214
Members71,862
Page 2 of 3 1 2 3
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #2504552 01/24/12 06:45 PM
B
Brons2 Offline
B
Beck/Arnley is now making a SPIII specific fluid. Problem is, it costs more than the SPIII at the dealer. I paid $6.60 a quart last time at the dealer, the B/A stuff is $11.99 at O'Reilly.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 5w & 10w30 seasonal, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Dealership Castrol 0w20, Mazda filter.
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #2504575 01/24/12 07:13 PM
jcwit Offline
Why do you wish to use something other than whats recommended by the manufacturer?
Re: What to replace Kia/Hyundai SPIII with? [Re: jcwit] #2504597 01/24/12 07:35 PM
A
artificialist Offline
A
Because there are fluids that have superior oxidation resistance, cold flow, and other properties that are superior to SP-III fluid.
In Canada, many Lancer Evolution and Lancer Ralliart models are having failed ACD pumps because SP-III fluid does not have good cold flow properties for example.
2010 Lancer Ralliart Sportback
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #2505193 01/25/12 11:32 AM
W
Wilhelm_D Offline
W
Originally Posted By: 04SE
What is the best replacement for Kia/Hyundai/Mitsubishi SP3? ….
I have read where Mercon V is the closest formula. Then I read where ATF +4 is the closest formula. Some people say that Valvoline Maxlife is the stuff to use ….
Here is what I have found with my Hyundai:
An elemental analysis of the SP II ATF is almost identical to an elemental analysis of Mercon V.
I have tried the following in my 2005 with zero problems shifting:
Red Line C+ ATF
Mobil 1 ATF
Mobil ATF 3309
I cannot say that they all feel identical, but they all seem to work. I like the cold weather performance of the synthetics.
I do a drain plug drain and refill every 30k miles, which changes about half the contents of the transmission.
Re: What to replace Kia/Hyundai SPIII with? [Re: artificialist] #2508936 01/28/12 10:28 PM
jcwit Offline
So the manufacturer is putting inferior products in the vehicle. OK, now we know!
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #2528873 02/07/12 10:24 PM
K
keith Offline
K
Mobil 1 Synthetic ATF would work for both your engines.
Whatever you do, don't put ATF in the engine smile
I tried Amsoil Universal in my wifes 2007 Elantra and didn't like it. The shifts were too slippery. My mechanic brother-in-law borrowed the car for a day and said be careful, the tranny is about to fail! Drained out the Amsoil and put SP-III back in, shifted quality was back to normal. That was at about 50K miles. When the car got close to 100K miles, and no more warranty, put in ATF+4 and that also shifts great. ATF+4 worked for me.
BTW - I always do a complete flush - pop off the AT hose and run about 12 qts. through.
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #2533367 02/11/12 10:37 PM
A
ahoier Offline
A
I recall reading a thread, someone mentioned "ATF+4" is actually suitable for Kia/Hyundai's "SPIII" spec......and it's kinda ironic, cause the "ATF+4" (which is actually licensed by Chrysler....) states right on the bottle suitable for Dodge, Chrysler, Jeep, Kia, Hyundai....
Thhhhooouuuggghhh....for those under warranty it does NOT list the "SPIII" spec on the backside wink
But, we all know by now, when it comes to trans/engines....ANY fluid/oil is better than NO fluid/oil :P
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #2553291 03/01/12 12:04 PM
F
fisher83 Offline
F
+1 for sticking with the SPIII. I have owned 3 Hyundai/Kia vehicles and always used the SPIII. My sister in law owns a 2005 Kia Rio and was recently told she needed a transmission flush. I cautioned her to either take it to the dealer to get it done or buy the SPIII and take it to her independent mechanic to install. 200 miles and a $400 tow bill later, she now has the car in the shop having the transmission flushed out and replaced with proper SPIII fluid. Not sure what fluid her mechanic used but the trans began slipping badly and she had to have the car towed over 100 miles for repairs. (we were on vacation) But she "saved" $50 over having the dealership do the flush.... I looked at alternative fluids and the price difference isn't worth the risk. SPIII is about $7 a quart here.
2019 Subaru Impreza 2.0i Sport 5,800 miles
2020 Ford F-150 STX 4x4 550 miles
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #2553959 03/02/12 12:33 AM
F
fisher83 Offline
F
Eneos now makes a SPIII fluid and my local NAPA has it for $4.99 a quart. From the sound of it, the fluid is supposed to be a direct replacement and not a multi-vehicle type formula. Our local Hyundai/Kia dealers are charging around $7 a quart for the OEM stuff. I really don't know though if the Eneos fluid has any advantages over the factory stuff. I've never found any solid info on who actually makes the OEM fluid.
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #5189851 08/17/19 07:36 PM
SureshR Offline
Hi, I picked up a 2012 Hyundai i10 tiny hatchback for my wife to use as a local beater. It requires a Hyundai specific ATF MX3 spec transmission lube. As Iā€™m rather far from the nearest Hyundai service center, what is the nearest compatible equivalent in a more common standard like Dexron or Mercon?
2014 Ford Fiesta 1.5 TDCI (Mobil F1 5w30 A5/B5 Ford WSS-M2C-913D) | 2015 Mahindra Scorpio 2.2 mHawk (Amsoil CK4 Turbo Truck)
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #5190001 08/18/19 12:21 AM
dubber09 Offline
I'm using MaxLife in my two cars, works great.
I did full exchange (not flush) myself on both first when Forte had 30K miles and Sportage had 20K miles, now doing D/F every 30K miles on both.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #5190424 08/18/19 02:26 PM
K
KevinP Offline
K
MaxLife ATF in both of my Kia transmissions. I have probably 70K on the fluid in both and notice no change in transmission behavior.
I drain/fill every 25K. It is "lifetime" fluid but I just prefer to keep the fluids clean.
Re: What to replace Kia/Hyundai SPIII with? [Re: KevinP] #5191623 08/19/19 08:32 PM
Smith5361 Offline
Do the kias have a drain? Didnt think my wifes okd Optima did
Re: What to replace Kia/Hyundai SPIII with? [Re: Smith5361] #5191904 08/20/19 09:00 AM
sw99 Offline
Yes
Re: What to replace Kia/Hyundai SPIII with? [Re: 04SE] #5192151 08/20/19 03:11 PM
M
mrdctaylor Offline
M
I had a 2003 Hyundai Santa Fe. I did 30K miles drain/fills and always used SPIII. It was cheap enough--sometimes I could find it on ebay. I owned the car for 14 years and sold it a year or so ago with 230K miles and the transmission still shifted perfectly. SPIII may not be the greatest ATF ever made, but it worked well for me. I've also heard lots of people used Maxlife with good success. Personally, I was never tempted to deviate from the OEM fluid.
02 Tacoma 3.4L, 233K, Hav ProDS 10W30 (me)
12 Highlander 3.5L, 115K, Napa Syn 0W20 (wife)
17 Escape 2.0L, 53K, P66 Shield Choice SynBlend 5W30 (son)
Page 2 of 3 1 2 3
