Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
103 registered members (Aero540T, 2010Civic, 330indy, 2003f7, 928, 12 invisible), 2,228 guests, and 17 spiders.
Topics301,931
Posts5,205,678
Members70,801
Nissan 15208 9E01A oil filter #5190275 08/18/19 09:35 AM
P
passgas55 Offline OP
P
I have a 2019 Nissan Frontier with the 4.0 V6 engine. I was looking for the specs for 15208 9E01A oil filter
which I could not find. Seems here it is believed to be a good filter. Anyway during my search this filter is also used on
the R35GTR and 370Z. I just find it odd same filter for the truck and on their sport cars. I thought the cars would have had a "more performance"
type filter.
While under warranty I will stick to the 5k oil and filter change. I find the 5k change a waste of oil and filter. Still deciding on a 5k filter besides nissan in the $4 to $6 range. Once warranty is over I will go extend to 7k oil changes and 14k filter changes either fram ultra or wix xp.
Re: Nissan 15208 9E01A oil filter [Re: passgas55] #5190347 08/18/19 11:18 AM
slacktide_bitog Online Content
Online Content
Use Fram TG or regular Wix smile
I know Nissan likes the shorty filters, but longer ones usually fit. Fram TG7317 or Wix 57356
Re: Nissan 15208 9E01A oil filter [Re: passgas55] #5190369 08/18/19 11:40 AM
H
hallstevenson Online Content
Online Content
H
type filter.
Not sure that there's any such thing as a "performance" oil filter. Nissan/Infiniti uses (2) filters across their entire model line-up. As a general rule, anything 4.0L V6 or larger uses the 9E01A filter and everything else uses the 65Fxx filter. The filters actually have the same thread and gasket ID/OD so you can interchange them. The only issue might be the "length" of the 9E filter and it not fitting. My Infiniti G35 specs the smaller 65Fxx filter but I have the room for the larger filter.
Re: Nissan 15208 9E01A oil filter [Re: passgas55] #5190522 08/18/19 03:43 PM
A
ARCOgraphite Offline
A
Just a note since I've used these filters.
They are Gonher Mexico. Maybe Grupo Gonher online has some spec.
Also make note that most all Asian cars use the same filter - except Toyota is different.
So, Nissan, Infiniti, Honda, Subaru, Mazda, Mitsubishi, Kia, Hyundai etc.use the same: base plate, gasket ,thread. with minor can length and diameter variations. Some MFG spec a higher bypass than others
They seem to be well made I can cut one for you if you want but I'm sure there are pictures online. I used them and the TG and the Honda on my Nissan Rogue Select QR25DE.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Nissan 15208 9E01A oil filter [Re: passgas55] #5190645 08/18/19 06:22 PM
P
P
ARCOgraphite No need to cut one open. I have seen a few pics and they do look well made. I just do not want to order online and the dealers
around here are not cheap.Since I have to do 5K oil /filter changes I may go with the fram TG or WIX which I can get locally. It will be changed every 3 to 4 months.May buy the NAPA Gold when on sale. I am used to 10k oil/filter changes I had before . I don't know why Nissan wants 5K changes in a ported engine. My oil will be Havoline Pro DS.syn.
