Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
101 registered members (BBDartCA, AZjeff, 69GTX, 53' Stude, ammolab, 12 invisible), 2,789 guests, and 22 spiders.
Topics301,831
Posts5,203,551
Members70,787
Window flashing tape #5189889 08/17/19 07:27 PM
spasm3 Online Happy OP
OP Online Happy
Replacing windows, i have used 3M 8067 all weather flashing tape to cover the sill instead of black plastic, and i used it to cover the nail fins on the top and sides after the window is installed.
My question is, is it the right product to use on the sill, the product info says yes, it has a wide temp range. But how does it compare to the rubberized asphalt tapes ? I'm fine with the 3m tape on the nail fins, but is the the best for covering the sill under the window??
Thanks.
https://www.amazon.com/3M-Flashing-...Y5FO/ref=cm_cr_arp_d_product_top?ie=UTF8
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Window flashing tape [Re: spasm3] #5189897 08/17/19 07:43 PM
B
Blaze Offline
B
I just bought a roll of Vycor Plus. Replacing two windows. I haven't opened the roll but from the outside edges it looks like a asphalt rubbery product with a polyurethane coating. I would think this would be fine for sills and that's what it says it for too.
Re: Window flashing tape [Re: spasm3] #5189919 08/17/19 08:10 PM
M
maxdustington Online Content
Online Content
M
Is it the best? No, that's what the rubberized stuff is for. Will it work? It will probably last as long as the windows as long as everything else is installed correctly. You should be looking at building codes instead of what 3M's marketing department thinks their product can be used for.
Depends how cheap you are v your desire to get the job done right. You can just remove the window if it leaks and apply the rubberized stuff without damaging the window while removing it...right? Maybe on a ground floor window but I wouldn't be cutting corners on a window that you need a ladder to install, that's just stepping over dollars for dimes.
99 Toyota Tercel CE 5EFE/C151
Re: Window flashing tape [Re: maxdustington] #5189921 08/17/19 08:14 PM
OP Online Happy
The 3m costs more than the rubberized. II was just hoping for some wisdom from those who have used the rubberized sill tape. It sounds like you prefer the rubberized ashphalt tape correct? Local code is probably not that informative as black plastic wrap stapled is code, but not that great.
Re: Window flashing tape [Re: maxdustington] #5194569 08/23/19 10:21 AM
L
Linctex Offline
L
Codes are usually pretty vague....
Besides, 3M data sheets are gospel.
We "glue" fighter jets together with their adhesives (it's a little more involved than that, BTW)
I have never had a product of theirs fail when used within specified guidelines. Their products are always worth the extra cost.
Re: Window flashing tape [Re: spasm3] #5194678 08/23/19 12:43 PM
B
BMWTurboDzl Offline
B
It's acrylic which is a much better adhesive than butyl tape. You'll be fine. Just make sure you've installed the windows as directed by the window manufacturer.
435i
