Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
105 registered members (53' Stude, ammolab, Astro14, 74Widebody, ABursell, 97prizm, 10 invisible), 2,873 guests, and 23 spiders.
Topics301,829
Posts5,203,524
Members70,787
Motorcraft FA-4 spec oil #5189861 08/17/19 06:46 PM
F
FlyingTexan Offline OP
F
Firstly, if an oil meets a stringent spec like FA-4 does it matter who makes it? Secondly any reason to not go with Motorcraft? Thirdly is there really any special testing done by Ford or is it just a marketing gimmick? I have the 3.0l TD6 engine and just picked up two cases of 12 quart for $80 each on eBay.
Also, how often should I really change the oil? Just wait for the computer to tell me, do it seasonally, annually?
Re: Motorcraft FA-4 spec oil [Re: FlyingTexan] #5189920 08/17/19 08:13 PM
N
NH73 Online Content
Online Content
N
Is the 3.0l in a F-150? Does that engine require a FA-4 oil?
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Motorcraft FA-4 spec oil [Re: FlyingTexan] #5190128 08/18/19 06:51 AM
B
bullwinkle Offline
B
There's been a lot of testing of FA-4 oils, and if an engine is built for it-slightly higher MPGs can result from using it. Depends on how much you trust Ford's diesel engine program, I'm in the once bitten, twice shy category (6.0 PSD issues).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Motorcraft FA-4 spec oil [Re: bullwinkle] #5190532 08/18/19 03:51 PM
M
mattd Online Content
Online Content
M
The 6.0 is actually a very reliable engine with some minor changes and with updated parts.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Motorcraft FA-4 spec oil [Re: mattd] #5190572 08/18/19 04:57 PM
B
bullwinkle Offline
B
Sure, an EGR cooler, a set of head gaskets with ARP studs (which generally means taking off the cab or pulling the engine out the front with a forklift or similar), maybe a VV turbo (or 3 as we had a few of the 6.0 PSD vans need), maybe a set of injectors, a FICM, and/or an HPOP at $1K each?? That's not minor in my book.
Re: Motorcraft FA-4 spec oil [Re: bullwinkle] #5190684 08/18/19 07:24 PM
M
Online Content
M
The minor changes are an EGR delete, studs, updated stand pipes, dummy plugs and STC fitting, and a coolant filtration system with a silicate free ELC coolant. the 6.0 and the 6.7 are the most reliable trucks we have. All our 6.0s have he cooler deleted. The 05+ pumps rarely fail. The 03-04.5 trucks have the adrenaline pump from dieselsite that have proven to be much more reliable than the OEM. Injectors with mileage or poor maintence sure. It’s a wear item. FICMs usually (key word here) fail from bad batteries. A new one from ford is 480$ pre programmed. The biggest expense is studs sure. Al the hour meters have been maxed out on all the 6.0s for years and only 1 set of head gaskets. 0 HPOPs, 1 FICM, and 2 out of 7 6.0 trucks got Injectors that’s it. These are all rescue cab and chassis. F series.
OP sorry for the derailment.
ASE Master, L1, L2
Re: Motorcraft FA-4 spec oil [Re: mattd] #5191758 08/20/19 01:06 AM
B
bismic1 Offline
B
This has very much been my experience also!
2006 F250 6.0L PSD CC SB FX4
Re: Motorcraft FA-4 spec oil [Re: FlyingTexan] #5192028 08/20/19 11:43 AM
J
Jimmy_Russells Offline
J
Keep in mind also the 6.0 was mainly an Interntional design, the 6.7L which is actually designed by Ford only has been a reliable engine.
Re: Motorcraft FA-4 spec oil [Re: Jimmy_Russells] #5192176 08/20/19 02:32 PM
M
Online Content
M
You are correct
ASE Master, L1, L2
Re: Motorcraft FA-4 spec oil [Re: Jimmy_Russells] #5192177 08/20/19 02:33 PM
M
Online Content
M
You are correct
ASE Master, L1, L2
Re: Motorcraft FA-4 spec oil [Re: mattd] #5192179 08/20/19 02:33 PM
M
Online Content
M
Double post sorry
ASE Master, L1, L2
Re: Motorcraft FA-4 spec oil [Re: bullwinkle] #5193285 08/21/19 07:00 PM
G
Garak Offline
G
My concern is that Ford is so petrified of CK-4 oils, yet there's a Motorcraft FA-4? I think Ford really needs to do something about their conflicting messages with respect to diesel engine lubrication.
Plain, simple Garak.
Re: Motorcraft FA-4 spec oil [Re: FlyingTexan] #5193874 08/22/19 12:11 PM
53' Stude Online Content
Online Content
Yeah Garak, Ford definitely has issues with their oil "preferences)
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Motorcraft FA-4 spec oil [Re: 53' Stude] #5194061 08/22/19 05:12 PM
G
Garak Offline
G
I'm not even sure what they have that would call for FA-4. The smaller half ton diesels have generally gone to a C3 type lube, which has higher HTHS. Then, when they find something doesn't pan out, they go to an ordinary E7, E9 HDEO.
