I have zerk grease fittings on my 3/4 ton Chev. On one inner tie rod end I could not get the grease to feed. I changed out the grease fitting to another one from an old package of new fittings. It would still not feed (pressured up). The rubber boot on the inner tie rod end was not full. I picked out a 2nd fitting and installed it but it would not feed. I then went to the auto store and bought a new fitting and installed it. I could still not feed grease through it. I checked the gun on another fitting on the other inner tie rod end and it fed no problem. Anyone ever run in to this type of situation? Thanks.
