toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
46 registered members (Black, bbhero, 53' Stude, Amenhotep, 6 invisible), 960 guests, and 15 spiders.
Topics301,817
Posts5,203,212
Members70,784
2003 Buick LeSabre...freon refill still blowing warm air #5189636 08/17/19 01:46 PM
A
AshleyQuick Offline OP
A
The vehicle was blowing hot air before the refill. Now, it's not exactly hot but still not cold. Any likely problems??
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189643 08/17/19 01:59 PM
Nick1994 Offline
Early 00's GM cars often have bad blend door motors under the dash, and other bad electronic motors. Might be stuck warm.
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: Nick1994] #5189666 08/17/19 02:25 PM
A
A
Is there an easy way to check that?
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189670 08/17/19 02:30 PM
Chris142 Offline
What are your high and low side readings as well as ambient temp? Without these it's all a guess.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: Chris142] #5189678 08/17/19 02:40 PM
A
A
Can these readings be found by visiting an auto parts store? Otherwise, I have no idea how to measure for those.
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189684 08/17/19 02:45 PM
skyactiv Online Content
Online Content
Take it to a Valvoline Instant Oil Change location and have them check the pressures and refill if needed.
Auto parts stores wont help you, but they will sell you a can with a worthless gauge for half the price of getting Valvoline to do a proper vac and fill.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189743 08/17/19 04:01 PM
K
kstanf150 Offline
K
I had a truck years ago with a bad blend motor
I was able to remove the glove box and reach in the dash to move the blend arm
Maybe that’s an option for you as well
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: Nick1994] #5189837 08/17/19 06:18 PM
J
JGmazda Offline
J
Correct. My 2001 LeSabre has the same issue. I believe there is electronic servo motor that can be reached from under the glove box. In my case, the driver's dash vent will blow warm air and the passenger's is Ice cold. I have yet to fix the issue. Make sure your AC is working first! You don't want to blame a "blend door" without investigating your AC system.
2008 KIA Sportage
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189915 08/17/19 08:06 PM
P
pitzel Offline
P
I had a similar problem on a similar car, the actual door inside was completely displaced from its mount.
Agree with the others, a proper diagnosis should have been performed prior to simply assuming it was a case of refrigerant deficiency. Overfilling refrigerant can be detrimental to a system.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189974 08/17/19 10:03 PM
T
ted s Offline
T
likely its over charged
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189978 08/17/19 10:08 PM
spasm3 Offline
Have to make sure the radiator fans work, and you need high and low pressures. Also is the compressor clutch engaging?
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5189981 08/17/19 10:16 PM
clinebarger Offline
Put your hand on the Accumulator with the AC on....If it's ice cold, So is the Evaporator. If ice cold....Suspect a Temp Blend Door issue.
2001 Chevy Camaro L92/4L80E
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5190201 08/18/19 08:10 AM
E
exranger06 Offline
E
How did you determine it needed more refrigerant in the first place? Did it have a leak that you fixed? Did you vacuum the system down afterward? How many ounces of refrigerant did you add and how did you measure the amount you put in?
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: AshleyQuick] #5191140 08/19/19 09:10 AM
A
A
So I took the car back this morning and he showed me, using a UV light and yellow tinted glasses, that the refrigerant was leaking/splattering. He said I'd need a new climate control hose assembly.
Re: 2003 Buick LeSabre...freon refill still blowing warm air [Re: Nick1994] #5191276 08/19/19 12:28 PM
L
Lubener Offline
L
If it is a blend door issue, the system probably is over charged now. If someone is not familiar with A/C systems, they usually do more harm than good by assuming the system is low on charge and start putting refridgerant in.
The best answer to this is to have someone qualified look at it and stop guessing.
The "thinking" man's friend.
