Croma, 1.9 Diesel DPF, 150hp.
Considering that the Owner Manual recommend the Spec. Fiat 9.55535-M2/N2 or at least ACEA B4, is it OK to use the following (new specifications for DPF engines) such as:
ACEA C1 (Lowest SAPS-Level, HTHS Viscosity of 2.9 mPaâ‹…s)
ACEA C2 / C3 (Mid SAPS-Level, HTHS 2.9 / 3.5 mPaâ‹…s.)
ACEA C4 / C5 (Low / Mid SAPS-Level, HTHS 3.5 / 2.6 mPaâ‹…s)
Specifically i would like to use Total Quartz Ineo MC3 5V-40 (low SAPS, ACEA C3, API SN/C, Fiat 9.55535-S2, FIAT 9.55535-GH2) ?
