I recently acquired a Honda HRX217 with a bad engine. Previous owner was gonna just toss it but the plastic deck is really nice. Figured I'd take a shot with it. My goal was to maintain 100% functionality with original factory controls and retain the Honda blade system underneath. Picked up a 173cc Predator for about $130 and went to work. It wasn't a straight forward swap. The original GCV190 has a 25mm shaft, the Predator a 7/8" plus the mounting holes aren't quite the same. I got a 7/8 to 1" adapter from Amazon that was too big. Of course it was. Why wouldn't it be? I ground that down a bit at a time until it fit. The Honda blade adapter did not go on the Predator without a fight. Eventually I got it all together, the belt and transmission all hooked up, all pieces and parts back together (do you have any idea how many parts there are under a Honda deck??!! Do you?? No. You do not.). Gas. Oil. Pull rope four or five times. Scratch head. Remember to push primer bulb. Engine unexpectedly starts 1/2 way through first pull. Release "clutch" handle that inadvertently engaged self propel mechanism in 3rd gear racing mower across garage into barbecue grill. Crack celebration beer. Ugh. So at the end of the day it all worked. Everything. All factory controls are functional. Blade brake fit right on with no changes. Throttle cable required a slight change but was easy. The engine runs. like. a. dream. Only 2 of the 4 mounting holes could be used but I used Grade 5 hardware with lock washers. Where the heck is it ever going to go? Original Honda blade is on and at the correct height. I paid $599 for the other HRX217 in my garage so the sub $200 I have into this one seems reasonable. Oh. Y'all ask so: First oil was the cheapest 10-30 I could find on my way home. O'Riellys Auto Parts brand gets to be in there for the first few hours and usher out all the glitter. Then it gets Amsoil DEO like everything else in my garage. This occasionally gets subbed out for Rotella T6 or Mobil 1 TDT. I always use a good synthetic 5w-40 diesel engine oil.
