2012 GMC Terrain 3.0L V6 Valve Cover Replacement
by benjamming - 12/06/19 07:30 PM
Cam2 CVT fluid is green, and so is Transtar
by slacktide_bitog - 12/06/19 06:59 PM
Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
Stahle, BajaBu, Bayoubrad, Fog42, glassmaker
70053 Registered Users
117 registered members (alphadog, ammolab, andyd, AC1DD, 12 invisible), 2,055 guests, and 41 spiders.
Topics298,384
Posts5,134,234
Members70,053
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Anyone Use Schedule 40 PVC For Air Lines ?? #5188480 08/16/19 05:46 AM
B
billt460 Offline OP
B
Now that I've got a nice big garage, as soon as the weather cools down a bit, (and I get my strength back after this back breaking move), I want to run air lines around the walls of my garage, and tie them into my air compressor, so I don't have to drag it out all the time.
I'm thinking of using 1" or 1-1/2" Schedule 40 PVC. It has more than a high enough pressure rating, it's also cheap and real easy to work with and get a good seal on. I can buy those galvanized U shaped brackets and screw them into the studs every 3 or 4 feet. Then splice in Tee's every 8' or so. From the Tee I can install a female pipe threaded cap, then go with a male brass connector to a Milton quick disconnect.
I can also tie in a retractable 50' hose near the door, which will get me well out into the driveway. I can hang several short hoses, (10' or so), at or near the quick disconnects around the entire inside of the garage. I don't care for those coiled hoses. Most of them don't last, they're a PITA, and are very clumsy to work with. And they are prone to kinking if you try to pull them around anything. I can even run a section of pipe through the wall outside for blowing off gun parts, etc. Having compressed air handy in a garage is always nice. Especially now that I have one I don't have to walk sideways through.
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188481 08/16/19 05:49 AM
spasm3 Online Happy
Online Happy
I would not. I think that may be dangerous. They can explode and its shrapnel. Its not OSHA in any shop.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: spasm3] #5188484 08/16/19 05:52 AM
B
billt460 Offline OP
B
Why would it explode? Schedule 40 pipe has a pressure rating of 450 PSI. My compressor puts out 150 PSI max. And 90% of the time I run it, I've got the regulator turned down to 90 PSI or less.
"1” schedule 40 PVC pipe has a .133” minimum wall and 450 PSI."
https://www.google.com/search?sourc...5i39j0i131.D4KDenuk31I#spf=1565956185215
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188492 08/16/19 06:05 AM
spasm3 Online Happy
Online Happy
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188497 08/16/19 06:09 AM
doitmyself Offline
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188501 08/16/19 06:19 AM
A
atikovi Offline
A
Why not use rubber air hose? Easier to route around corners and obstacles compared to rigid pipe. Something like Gorilla hose http://catalog.contitech.us/viewitems/air-multipurpose-hose/gorilla-air-multipurpose-hose has 500 psi working pressure.
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188505 08/16/19 06:27 AM
B
Bailes1992 Offline
B
Why not just use copper pipe and compression fittings?
19 Volvo V40 D3 Auto - 96 Defender 300TDi - 03 Ford Mondeo ST 3.0 V6
Engine - Castrol Edge 5w30 LL
Manual - Fuchs Sintofluid 75w80
ATF - Comma MVATF
Diff & Transfer - Fuchs Sintopoid 75w90
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: spasm3] #5188509 08/16/19 06:34 AM
T
Trav Offline
T
I use Maxline also from rapid air for my spray gun and breathing mask lines, great stuff and internally remains very clean unlike metal pipes. The problem with PVC is it tends to harden and become brittle with age and when subjected to oil fumes or mist.
Every oil compressor has some blowby even a new one and it only increases over the years, it isn't much but it doesn't have to be to be damaging. PVC is sketchy for compressor lines long term and if its a 2 stage high pressure unit an absolute no no.
The Maxline is 3 layer with aluminum not PVC, it is a type of alupex. Either the Rapid air 3/4 or 1" Max line will do a great job and last 50 years.
https://www.rapidairproducts.com/maxline
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: Bailes1992] #5188519 08/16/19 06:45 AM
Chris142 Online Content
Online Content
Super expensive!
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188521 08/16/19 06:47 AM
M
MasterSolenoid Offline
M
Without saying you have a good or bad idea.
One thing I have learned over the years (doing electrical and plumbing jobs) around my house is,
What is the industry standard ?
I believe it's easy to do better then Code (neater) but don't do it different.
As I have gotten older & wiser, I have redone several jobs around my house (previously done by myself).
Do it to industry standard and you will never regret it.
Enjoy your new garage,
My garage is attached and I installed a Wash Tub Sink that gets a lot of use.
Retractable Extension Cords are also nice.
Edit: If your still unsure how to proceed, give it more time and thought, eventually the correct method will
come to you and you'll know why.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188523 08/16/19 06:50 AM
W
WyrTwister Offline
W
IF you do , be sure you use primer on the joints / connections . Before you glue them .
https://www.google.com/search?client=firefox-b-1-d&channel=cus&q=2+hole+rigid+conduit+strap
Might want to use 1 size over-size strap to give the PVC room to " move " . Also , might want to pad the area at the strap with something like foam insulation .
Personally , when I worked maintenance at the foundry , back in the stone age , we ran a lot of 2" schedule 40 black iron pipe . I have never used PVC for air . Ran my share of PVC conduit , but it does not have to hold pressure .
Best of luck to you , :-)
Wyr
God bless
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: Trav] #5188529 08/16/19 06:59 AM
B
billt460 Offline OP
B
This stuff doesn't look too difficult to work with. And it's reasonable. (I would need a couple of hundred feet). The main thing would be installing it with the hoses tight enough, and with enough mounting connectors so it would look like something when I'm finished, and not be drooping everywhere. The stuff looks like PEX.
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188537 08/16/19 07:13 AM
A
ARCOgraphite Offline
A
The piping is going to contain oil and water after just short use. How will this mess react with PVC sched40? I cant imagine well. Maybe a Chemist / ChemE can chime in.
Beswick 1/4" Polyurethane flexible tubing is used in industry for vacuum and compressed air. I would just go with that.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188560 08/16/19 07:33 AM
E
exranger06 Offline
E
Do a search over on garagejournal.com about PVC air lines. It's been discussed to death over there countless times. The consensus: don't do it. It can and does burst, sending shrapnel everywhere. I'm currently plumbing my garage up with copper Type L pipe and soldering fittings. Black iron pipe is also an acceptable material.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Anyone Use Schedule 40 PVC For Air Lines ?? [Re: billt460] #5188562 08/16/19 07:34 AM
L
Linctex Offline
L
I've had PVC and CPVC (mixed) for over 20 years and it's fine. 135psi max
1.5"??? You working on semi trucks?
Most of mine is 3/4" and 1/2"
Page 1 of 3 1 2 3
