Hello Everyone,
I don't know much at all about an oil analysis, so it'll be great if some of you guys can give me some more insight(if available) other than the general information provided Blackstone.
I've used Pennzoil Ultra Platinum 5w-30 with a K&N Performance oil filter (I called K&N and they did say the filter membrane is different than the Pro series) throughout the trucks life. I've always changed the oil every 5000-5500 miles EXCEPT this last OCI. This last OCI was done with about 9000 miles on the oil and filter. During the OCI, the fuel tank was filled with Gumout One-And-Done fuel treatment(if this fact has any bearing). The truck was ran a little harder while filled with the Gumout in the tank because I figured it would help get the engine temps up assisting the clean. Thanks in advance.
R
R
