Watching this video got me thinking about the abysmal climb rate of many piston powered aircraft. My own plane included.
I posted the following in the video's comment section:
"Underpowered. Period, end of story. Airborne for 10 seconds and can't continue a basic climb with a 5 degree pitch attitude. Yes, I understand energy management and his pitch up (and stall) at the end to avoid tree tops. But it's high time we stop accepting aircraft that climb at 400 FPM. It's easy to say he needed more room because he did. But once airborne, any aircraft should have enough power to climb at a very positive rate, not mush around at the tree tops. I suggest a 1500 FPM climb rate is the light aircraft level of power required for minimum safety. We don't need straight up climb capacity, but we do need sufficient power to climb with authority under ALL conditions, including in sinking air masses, turbulence, higher elevations and temperatures. Aviation is chock a block full of climb accidents."
I've been annoyed at the performance of my 2800 pound, 200 HP plane (Cessna 177RG) for some time. It's hot n humid in Florida/Georgia where I normally fly. Once at 100 pounds under max gross, I had to request the long runway at DAB. (prior to the Powerflow exhaust and K+N airfilter, which do help) . I've since learned to keep it light and fly alone. Any way you slice it, 14 pounds per HP is on the anemic side. Book numbers show ROC at 800 FPM at max gross. Hahahaha Liars...
In any case, my thoughts are a work in progress, but I've come to believe there should be a more robust climb standard for all single engine aircraft. An airplane that can make 1500 FPM at STP (sea level, 59 deg F, 29.92 in hg) is one that can perform well enough to have a very positive initial rate of climb from the time the wheels lift off.
Climb is excess thrust, and even small increases in HP markedly improve climb rates.
