121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
103 registered members (askani79705, ABchevy, ArrestMeRedZ, 2K2AcuraTL, aquariuscsm, 53' Stude, 10 invisible), 2,151 guests, and 18 spiders.
Topics302,043
Posts5,207,968
Members70,825
My Good Deed for the Day #5187054 08/14/19 01:32 PM
CR94 Offline OP
This morning at the local Walmart, I again checked out their selection of cartridges to fit my Toyota, including the Fram Ultra 10358. I looked at only one.
The good news was that the pleats of today's example were much more uniformly spaced than I'd seen on earlier examples in which about half the pleats were crammed together into maybe a third of the circumference---so tightly it is hard to imagine how oil could easily get past the non-existent gap between the inner creases. Big improvement!
However ... Looking into the center hole, I saw a small piece of metal protruding inward from the metal screen backing. It extended far enough toward the center that it would not have cleared the center tube of the housing, if someone installed it. I decided to poke at the protruding piece to see whether it would break off easily. As soon as I touched it very lightly, it fell off in the floor. It was apparently completely loose, resting between the metal backing and the center hole of the end cap. In hindsight, I should've found and picked up the fragment and measured it, since someone here is sure to inquire how large it was, or want a photograph. It was "X" shaped, evidently a stray fragment of the backing material, about as large as it could be without including more than one intersection of the criss-crossed pattern. Maybe roughly 1.5×2.0 millimeters.
Perhaps as a result of my tampering with the merchandise, that steel fragment will not end up in a very bad place in someone's engine.
2011 Toyota Prius now at 109K
Re: My Good Deed for the Day [Re: CR94] #5187062 08/14/19 01:42 PM
K
KGMtech Offline
K
Did you put it into the cheaper filter box? that's SOP for Walmart filter shoppers from what I hear...
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: My Good Deed for the Day [Re: CR94] #5187081 08/14/19 02:13 PM
Z
ZeeOSix Offline
Z
Always a good idea to thoroughly inspect any filter before buying. Stuff can happen during production with any oil filter.
Re: My Good Deed for the Day [Re: KGMtech] #5187100 08/14/19 02:37 PM
A
ad244 Offline
A
Hahahahahaah^^^
Re: My Good Deed for the Day [Re: KGMtech] #5187110 08/14/19 02:45 PM
W
WhizkidTN Offline
W
One of the reasons why I buy direct from Fram on Amazon. THEN, I inspect the still sealed box. Another reason is my local Walmart's are almost always out of stock for the XG9688 I use.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (87K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (100K)
>EDGE 0W-20, Fram XG6607/XG7317
Re: My Good Deed for the Day [Re: CR94] #5187221 08/14/19 05:17 PM
F
Farnsworth Online Content
Online Content
F
The real pink media Ultra screen is very tough stainless steel. I can see where manufacturing it and working with it is challenging. Very near the Ultra is the Toyota Denso which is metal free.
Re: My Good Deed for the Day [Re: Farnsworth] #5187265 08/14/19 06:04 PM
CR94 Offline OP
The media in the 10358 Ultra is gray.
I assume the screen is the same as in spin-on Ultras. Agree that that stuff could be challenging to work with. Finding a loose fragment of it ready to go into the oil gallery is still a surprise.
The corresponding Denso (Toyota) cartridge has a very different set of advantages and disadvantages; I'm not clear in what sense it's "near the Ultra," unless possibly in overall desirability.
Re: My Good Deed for the Day [Re: CR94] #5187416 08/14/19 09:19 PM
Marco620 Offline
I have confronted management about having the checker match the filter to the box so that they make sure they are getting what they pay for theory. Gonna run this FU7317 out to 30K miles so I dont need filters for awhile. Dislike thieves more than liars; easier to catch!
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: My Good Deed for the Day [Re: CR94] #5187524 08/15/19 12:56 AM
2
2015Corolla Offline
2
It is pink.
[Linked Image]
2015 Toyota Corolla LE Eco
Ravenol ECS 0w-20
FRAM Ultra XG10358
FRAM Ultra XGA10190
Re: My Good Deed for the Day [Re: CR94] #5187714 08/15/19 08:40 AM
F
Online Content
F
On the shelves at WM, they are selling the Toyota filters <near> the Frams. They are a bit overpriced though. The discovery of such a large metal particle does raise questions about metal screens in filters in general and the mass production process.
Re: My Good Deed for the Day [Re: 2015Corolla] #5188407 08/16/19 12:11 AM
CR94 Offline OP
It is pink. ...
OK, pinkish gray, then.
Re: My Good Deed for the Day [Re: CR94] #5189065 08/16/19 06:19 PM
F
Online Content
F
Maybe you have some color blindness to red. The Ultra is not gray, unless two people here see gray as pink, which doesn't happen. People not seeing reds correctly does happen.
https://www.bing.com/images/search?...=IGRE&first=1&cw=1129&ch=517
