2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
96 registered members (1978elcamino, 762fermeandyou, AlienBug, AC1DD, 55hambone, Aichiguy, 6 invisible), 2,130 guests, and 17 spiders.
Topics302,049
Posts5,208,058
Members70,825
what type of oil to use #5186999 08/14/19 12:24 PM
J
john_chicago Offline OP
J
with a high mileage car 85k 2015 hyundai accent. some oil consumption. 5w20 oil..(monitoring it right now) so far 12 oz per 1200 miles. so in theory 30oz per 3000 miles is that a lot?
folks have suggested using 5w30 or 5w20 high mileage or go full synthetic....i am not leaking oil, pcv valve looks good ...no smoke ...could be rings..
have not done a compression test yet.. any thoughts?
Re: what type of oil to use [Re: john_chicago] #5187007 08/14/19 12:32 PM
SatinSilver Offline
Valvoline Maxlife (red bottle) 5w30. Followed by 5w30 Valvoline conventional, PYB 5w30, Chevron Supreme or Formual Shell from Home Depot. Prob stick to 5k oil changes with an oem filter.
What oil is being used now?
Re: what type of oil to use [Re: SatinSilver] #5187011 08/14/19 12:36 PM
J
J
my mechanic uses carquest ......let me back up and tell the story ...i usually have my mechanic do oil changes. but i was in a hurry and went to one of the chain change places
and at about 2400 miles the oil light flickered...i got to work and checked the dipstick and it was pretty low ...i immediately added a quart and went to my mechanics that evening
they could see any leaks or smoking...didn't do a compression test (yet) we changed the oil and started a new keeping a log checking the level weekly ...hence where i am at now.....not blaming anyone but he thinks they either put the wrong oil in or not enough or both......
Re: what type of oil to use [Re: john_chicago] #5187027 08/14/19 12:56 PM
K
ka9mnx Offline
K
First try a 5w-30. If that doesn't work, try a HM 5w-30. SuperTech from WM.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: what type of oil to use [Re: john_chicago] #5187035 08/14/19 01:05 PM
A
andyd Offline
A
Go back 2 Oil changes. Was it using oil between changes? Look for drips and check for a while. Be glad you caught it. Let your mechanic change oil. Couple weeks long on the interval isn't a deal. or go to a Valvoline franchise. Don't trust anybody check your oil every so often grin2
Thick oil is better grin2
Re: what type of oil to use [Re: andyd] #5187037 08/14/19 01:12 PM
J
J
you know i was not checking the levels...too much going on for me too remember to do so....but i am now!
but i always check under car for drips..never seen any...mechanic checked engine and pan for leaks ...nothing...
Re: what type of oil to use [Re: john_chicago] #5187046 08/14/19 01:17 PM
PimTac Offline
If your car has a splash shield underneath you might not see any drips. Pull the shield to double check.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: what type of oil to use [Re: john_chicago] #5187049 08/14/19 01:26 PM
B
burla Offline
B
I think he would notice 12 ounces every 1200 miles it if was dripping, it would be a dang oil slick, lol. Have you changed pcv? Probably past due if not.
Re: what type of oil to use [Re: burla] #5187065 08/14/19 01:44 PM
J
J
the pcv valve i know i have not changed it since i bought the car in in early 2017....i best change it
Re: what type of oil to use [Re: john_chicago] #5187084 08/14/19 02:16 PM
J
J
would it be worth my time to get a compression test done?
Re: what type of oil to use [Re: john_chicago] #5187088 08/14/19 02:22 PM
K
kschachn Offline
K
Welcome back by the way.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: what type of oil to use [Re: john_chicago] #5187118 08/14/19 02:53 PM
N
NormanBuntz Offline
N
No. Don't worry about a quart consumption over 3,000 miles.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 96K, original owner
2007 Infiniti M35, 115K, original owner
Re: what type of oil to use [Re: john_chicago] #5187119 08/14/19 02:56 PM
M
mrjlube Offline
M
Id change the pcv valve for sure and ive had great luck with Maxlife 5w30 Redbottle.
2017 Ford Escape ...ValvolineSynthetic 5w20
2009 kymco xciting 500...amsoil scooter oil...10w40
2001 Honda civic 5 speed 1.7.....Valvoline Maxlife 5w30
Re: what type of oil to use [Re: john_chicago] #5187138 08/14/19 03:21 PM
csandste Online Content
Online Content
Your engine is very suseptable to damage from low oil. Don't let it get low.
2017 Kia Soul Plus-- Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: what type of oil to use [Re: john_chicago] #5187143 08/14/19 03:27 PM
B
burla Offline
B
That isn't a lot of oil when considering burning, unless it is a new thing, then it's a sign. Have you changed plugs as well? I might start using a ucl as well, it isn't fact based but I have always been concerned with the new ethonal gas mixes long term. I like redline s-1 or amsoil pi, good pea numbers plus upper cyliner lube, cleans and protects, but many guys here run TC-W3 as a budget ucl. I'f I wasn't going to get all mechanical on it, I'd start using a ucl, 5w30, and at least clean pcv, and then monitor it.
