Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
108 registered members (Astro14, 5AcresAndAFool, 77GrandPrix, Alfred_B, A_Harman, 2015_PSD, 9 invisible), 2,209 guests, and 37 spiders.
Topics306,108
Posts5,286,598
Members71,586
Price spread trans filters '16 Camry #5186893 08/14/19 11:33 AM
A
andyd Offline OP
A
Prices on line vary from 26-65$. ATP? Wix? stick with OEM? I'm lining up parts for a drain and fill. TIA grin2
Thick oil is better grin2
Re: Price spread trans filters '16 Camry [Re: andyd] #5186902 08/14/19 11:41 AM
Donald Offline
I would go with a WIX any day. Maybe sure you get a decent gasket. Some include a cheap cork gasket, If you get one like that, toss the gasket and get a good gasket.
Some gaskets are fine to reuse.
For a car that new, I might not change the filter yet. I will bet its very clean.
Does the Camry have a drain plug. My 1994 did.
2015 Ford F-250 w/Powerstroke
Re: Price spread trans filters '16 Camry [Re: andyd] #5186913 08/14/19 11:59 AM
N
nthach Offline
N
The Camry does have a drain plug - you will also need a 8mm Allen or hex bit to remove the standpipe for the fluid level check in order to drain the pan.
Stick with OEM - that way you get the real Filtran filter made in the US(or a Toyo Roki filter made in Japan) and the nicer rubber gasket. Don't forget the O-ring and also these trannies are sensitive to fill level and temperature.
Re: Price spread trans filters '16 Camry [Re: andyd] #5186955 08/14/19 12:43 PM
A
andyd Offline OP
A
Thank you guys. I'v finally got comfortable changing the oil filter on the Camrys. Time to expand the skill set. The recommended drain interval for these is 30K? LE has 38K , SE, 48K. I reckon I can manage a drain into a graduated container on a cold car some morning. I tell you what, if the cars had a dip stick I could worry over, I probably wouldn't even consider doing a D/F Both cars motate fine. grin2
Re: Price spread trans filters '16 Camry [Re: andyd] #5187090 08/14/19 03:23 PM
J
JimPghPA Online Content
Online Content
J
Check YouTube there are several videos on doing the trany fluid on Toyotas.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Price spread trans filters '16 Camry [Re: andyd] #5187127 08/14/19 04:11 PM
dtownfb Offline
The recommended mileage to CHECK the transmission fluid is 60k miles not 30k. Replacement is only recommended if you operate in the severe zone (towing, short trips, etc). And the Camry has a sealed transmission so changing the fluid is a bit more detailed. Like JimPghPA mentioned, watch a few youtube videos before you get started.
Good luck.
2006 Toyota Camry
2013 Toyota Sienna
2015 Toyota Camry
Re: Price spread trans filters '16 Camry [Re: andyd] #5187274 08/14/19 07:18 PM
L
Leo99 Offline
L
Approx two quarts of ATF will come out through the drain plug after you remove the plastic pipe thing. I wouldn't mess with the filter.
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Price spread trans filters '16 Camry [Re: andyd] #5248150 10/23/19 03:34 PM
P
plankieee Offline
P
Fluids break down - decompose, wear out, it is not only mileage it is age (how long, this is a consideration). There is significant fluid remaining in the torque converter after a draining the transmission. I don't know the percentage, but it is significant. For the money saved by not buying OEM, might consider putting the saving into flushing all the fluid, disconnect the lines at the transmission radiator, the front wheels need to be blocked up so the wheels/tires can spin, no problem if it is on a rack, put buckets under each, intake, output, I would guess you need at least 3 gallons - you can return the unused. Run the engine, with transmission engaged, then I would suspect 97+% of the fluid is replaced. This is posted on you tube I am sure, I recall, if not is sure should be, The only reason I post this is that there is a significant difference in price between replaceing a transmission on a front wheel drive and rear wheel drive, this is a consideration. Don't forget the differential fuild. As for flushing, might consider doing the same procudure for you power steering fluid.
Re: Price spread trans filters '16 Camry [Re: andyd] #5435225 05/21/20 03:49 PM
J
JeffKeryk Offline
J
I am about to service the transmission in our 2013 GS.
The filter (strainer), pan gasket and o-ring was about $80 out the door at Lexus of Stevens Creek in Silicon Valley.
This is a good price, as most dealerships get $72 just for the filter.
I would use a factory filter, as you won't be doing this again for a loooong time.
Good luck and have fun with it.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Price spread trans filters '16 Camry [Re: andyd] #5435793 05/22/20 11:08 AM
CT8 Offline
OEM.
2015 F150 2.7
2018 F350 6.2
Re: Price spread trans filters '16 Camry [Re: andyd] #5436330 05/22/20 11:30 PM
U
UG_Passat Offline
U
$20 for the gasket and $58 for the filter... cheap enough to buy from Toyota.
https://parts.toyota.com/Toyota_201...-Driveline---Automatic-Transmission.html
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
