Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
98 registered members (87sammy, 2K2AcuraTL, 77GrandPrix, aquariuscsm, ABchevy, ArrestMeRedZ, 8 invisible), 2,180 guests, and 16 spiders.
Topics302,046
Posts5,207,982
Members70,825
Pour out the filter before second use? #5186682 08/14/19 07:23 AM
J
JoelB Offline OP
J
I want to start doing (2) 5k runs on my moms car on a fram ultra. In the past I've been doing 5k on supertech synthetic and supertech filter. I want to stick with the supertech oil but start doing the ultra every other oil change.
For any of you that run multiple oci's on 1 filter, are you unscrewing the filter and dumping out the old oil every time? Or are you just leaving it in place? I'm inclined to just leave it in place since its fairly messy removing it.
FWIW the car is a dodge journey 2.4L
Mine: 2020 Corolla SE
Factory fill
OE Filter
Wife's: 2018 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: Pour out the filter before second use? [Re: JoelB] #5186686 08/14/19 07:25 AM
B
Blkstanger Offline
B
No, I leave the filter alone. A half quart of oil isn't going to hurt.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: Pour out the filter before second use? [Re: JoelB] #5186688 08/14/19 07:26 AM
Astro14 Offline
If I were to go through the trouble of removing it, it goes in the trash. I’ve done all the work to change it, the gasket isn’t as likely to seal properly (o-ring in my case) so I’m likely to develop a leak...
And the only thing I’ve saved is $5?
Preposterous...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Pour out the filter before second use? [Re: JoelB] #5186710 08/14/19 07:47 AM
Chris142 Offline
Too much chance of contaminating the clean side with dirty oil if you remove it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Pour out the filter before second use? [Re: JoelB] #5186729 08/14/19 08:04 AM
R
ragtoplvr Offline
R
The clean side is the threads in the center. if you drain inverted then not going to contaminate anything.
However for filters with antidrainback valve, you will be lucky to get out more than half the oil. Filters without that valve, you might get out 3/4's s of the oil. I have done it and there were no leaks and no damage of the engine.
Rod
Re: Pour out the filter before second use? [Re: JoelB] #5186731 08/14/19 08:05 AM
H
hallstevenson Offline
H
Don't remove it - you risk messing up the gasket.
Waiting for the comments about why you shouldn't use a filter for multiple oil changes....
Re: Pour out the filter before second use? [Re: JoelB] #5186786 08/14/19 08:34 AM
J
JeffKeryk Offline
J
Leave it alone...
Like others have said, if you remove it, replace it.
I am starting to do this. It hurts... But I am getting used to it.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Pour out the filter before second use? [Re: JoelB] #5186822 08/14/19 09:09 AM
Snagglefoot Offline
Too anal.
If you want the job done right......do it yourself.
Re: Pour out the filter before second use? [Re: Astro14] #5186826 08/14/19 09:17 AM
B
billt460 Offline
B
Preposterous...
This ^^^^^^^^^^^^
Sometimes people carry the, "penny wise, dollar foolish" mantra to new levels. duh
Re: Pour out the filter before second use? [Re: Blkstanger] #5186831 08/14/19 09:23 AM
E
ecotourist Offline
E
I agree. Taking the filter off is an unnecessary chance to develop a leak.
I've been leaving the filter on for 2 oil change intervals in my Accord (just as Honda recommends) for a decade. Works fine.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Pour out the filter before second use? [Re: JoelB] #5186867 08/14/19 10:08 AM
Ded Mazai Offline
I would drain the oil from the filter because you contaminate the new oil if you don't. And you need to change the oil more frequently. This defeats the whole purpose of saving on a new filter.
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Pour out the filter before second use? [Re: JoelB] #5186868 08/14/19 10:09 AM
K
kmrcstintn Offline
K
as someone who does multiple oil changes while using the same filter (motorcycle/scooter) I leave the filter alone! it is properly seated & sealed so it stays until I am ready to change the filter...
btw...rationale for multiple oil changes (shorter oci): motorcycle transmissions shear oil viscosity & the volume of oil in the scooter is less than 1 qt and I feel additives get used up with the higher rpm's and thermal damage
'15 Jeep Patriot Sport (2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
Re: Pour out the filter before second use? [Re: JoelB] #5186869 08/14/19 10:10 AM
Mr Nice Offline
No.
Do NOT remove filter to drain oil.
Re: Pour out the filter before second use? [Re: JoelB] #5186952 08/14/19 11:41 AM
demarpaint Offline
This is where a cartridge filter has an advantage for those concerned with the oil that remains in the filter when doing an oil change. A cartridge filter can be removed, inspected, and used again. No wondering if the media is torn, loaded up, etc.
Regarding a spin on filter, if I'm going to go through the bother to remove it, I'll replace it with a new filter.
God Bless Our Troops
Re: Pour out the filter before second use? [Re: JoelB] #5186972 08/14/19 12:01 PM
Doublehaul Offline
I wouldn't remove it between uses
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
