Hard to say why you have chrome in the oil. Do any of your cylinders have an orange paint mark on them? That's generally the indication it's a chrome lined cylinder.
Also, have you borescoped the cylinders for indications of internal problems? As mentioned above, compressions OK? Oil consumption OK?
If you have a chrome lined cylinder, that will produce modest chrome levels in the oil.
The thing with aircraft engines is that a single UOA result is generally not useful. Typically, only the trend is useful.
EDIT: 50 hour oil changes are, in my opinion, too long. I try for 25 hours and sometimes go 30.
