Did this is just like sea foam or something else did it has some pea I can get this for $ 2.99 which 50% less than sea foam ? I try to find it here in bobtheoilguy can not find it if it has pea or just solvent?
Take a look at Berryman B-12 Chemtool Carburetor, Fuel System and Injector Cleaner - https://bit.ly/2YIyQFc
I've used it many times and it seems like a great product. A lot of professional mechanics swear by it. It's solvent based and not detergent based so it's said to be much better at dissolving gum, varnish, etc. You can buy it at your local WalMart for $3.47.
I have never used blue devil fuel cleaner, but if you know it has pea you know it is a quality fuel additive. So if it says directly or if you read on the back that it has pea in it then it is a quality fuel additive.
