Restoring an older Century Resorter inboard utility and did a final run up on a hose after I put her all back together. She ran great but I noticed that I wasn't getting as much water flowing out of one exhaust, but was pushing out more steam, and that riser was hotter than the other. Hoses seemed fine from the outside, but a friend (who knows more than I ever will about boats) suggested that I pull the hoses and look for this...delamination of the inner hose liner restricting the exhaust and causing water to pool and boil. Never seen anything like this before.
Basically, this is an aortic dissection of the hose.... Short term solution is a high heat fiberglass coupler splice, well above the water line, and a few feet of new hose. Winter solution will be two new hoses.
Pic is looking upstream, towards the engine.
