Hi -
I'm planning to start some periodic transmission drain and fills on my wife's U.S.spec 2017 Audi Q3. It just rolled over 50,000 miles. I'm hoping to run it for at least 200,000 trouble free miles… I'm 2+ hours from the nearest VW/Audi dealer and will be performing this myself.
I'm having a hard time determining what ATF to use. From what I understand the car has the same drivetrain as the VW Tiguan. The transmission code on the build label states QNU. I've searched, but I have not been able determine exactly which transmission this refers too..
Does anyone know definitively what is the factory fill ATF on these vehicles?
I'm thinking about using Pentosin brand but not sure which one ATF1 or ATF1 LV ?
What ATF would you use? Any advice would be appreciated..
Thanks!
Thanks!
