I'm looking to do a line off fluid exchange on the 05 Toyota Matrix and wondering which line to disconnect. There's two of them that feed into the radiator. Is it the left or right line that feeds into the radiator? I'm hoping to disconnect the rubber hose with my hands instead of a special if possible. Probably pump out 3 qts/refill then repeat. So exchange about 6 qts. If there are any other tips I'm all ears.
Thank you in advance.
