2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
114 registered members (762fermeandyou, AlienBug, 28oz, 4WD, 01rangerxl, 2K2AcuraTL, 7 invisible), 2,234 guests, and 14 spiders.
Topics302,048
Posts5,207,999
Members70,825
Page 3 of 6 1 2 3 4 6
Re: ACEA A5 or above. [Re: skyactiv] #5185002 08/12/19 11:11 AM
P
Petabytes Offline
P
Originally Posted by skyactiv
Just bought a used Elantra Sport with a higher output version of that engine and the owners manual is confusing.
What is above ACEA A5? My guess is ACEA A3 since Hyundai allows a 5W40 in these engines.
I put Pennzoil platinum 5W30 which listed ACEA A5 on the jug.
If you searched the Elantra Sport or Veloster Turbo user group on Facebook, they all recommended 5W40 for our 1.6T for better protection. Also there was a TSB already released by Hyundai mentioned about it.
I have also switched from the Pennzoil Platinum 5W30 to Motul X-Clean 5W40.recently.
Re: ACEA A5 or above. [Re: Petabytes] #5185013 08/12/19 11:27 AM
wemay Offline
There is no Hyundai issued TSB requiring owners to use 5W40.
19 VW Passat Wolfsburg TSI (VW Genuine 0W-20+OEM)
13 Hyundai Santa Fe Sport 2.0T (Shell RGT 5W-30+OEM)
Re: ACEA A5 or above. [Re: dave1251] #5185125 08/12/19 01:55 PM
A
avi1777 Offline
A
Originally Posted by dave1251
If you want further confusion DEXOS 1 Generation 2 is basically the ACEA A5 spec.
are you sure?
tnx
Re: ACEA A5 or above. [Re: MrMoody] #5185272 08/12/19 04:40 PM
G
Garak Offline
G
Originally Posted by MrMoody
It also says, "These Oils are unsuitable for use in certain Engines." Does anyone know any examples of gasoline engines and/or why? Just curious.
Another easy example is to think of diesel. A 5w-30 A5/B5 is technically suitable for certain diesel engines. I wouldn't be rushing to use it in a dexos2 diesel application or a Cummins, either.
wemay: It seems to be an industry wide issue of these manuals trying to cover every bit of legalese to the point that they're not saying anything useful.
Plain, simple Garak.
Re: ACEA A5 or above. [Re: Garak] #5186349 08/13/19 07:07 PM
wemay Offline
duh approved
Re: ACEA A5 or above. [Re: avi1777] #5186667 08/14/19 07:01 AM
V
Virtus_Probi Offline
V
are you sure?
tnx
A5 doesn't cover LSPI resistance at all, that will be covered with A7/B7 (and C6).
d1G2 was the first major oil spec to address LSPI.
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: ACEA A5 or above. [Re: 2003f7] #5186765 08/14/19 08:23 AM
E
edyvw Offline
E
Since this is turbo, OP should forget ACEA A5 or API SN+ and just use ACEA A3 or C3 5W30.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: ACEA A5 or above. [Re: edyvw] #5187063 08/14/19 01:43 PM
A
avi1777 Offline
A
and for a nonturbo but high compression 14.1 the a5 is sufficient?
tnx
Re: ACEA A5 or above. [Re: 2003f7] #5187086 08/14/19 02:20 PM
2
2003f7 Offline OP
2
My Tucson is a 1.6 turbo with D.I.
2002 Ford Excursion 6.8
1998 Dodge Dakota 5.2
2018 Hyundai Tucson 1.6T
Re: ACEA A5 or above. [Re: 2003f7] #5187106 08/14/19 02:40 PM
A
avi1777 Offline
A
ye i meant for my car sorry didn't mean to jack your post.
Re: ACEA A5 or above. [Re: avi1777] #5187350 08/14/19 07:46 PM
wemay Offline
tnx
More than enough
Re: ACEA A5 or above. [Re: 2003f7] #5187448 08/14/19 10:02 PM
E
edyvw Offline
E
Use ACEA A3 or C3.
You have Pennzoil Platinum Euro L in Wal Mart. It is MB 229.51 and better than ANY ACEA A5.
Re: ACEA A5 or above. [Re: avi1777] #5187449 08/14/19 10:03 PM
E
edyvw Offline
E
tnx
Yep. I use in my Toyota SIenna Mobil1 5W30 EP, ACEA A5.
Re: ACEA A5 or above. [Re: edyvw] #5187502 08/14/19 11:52 PM
A
avi1777 Offline
A
Use ACEA A3 or C3.
better,stronger ex sure but isnt it over kill?
Re: ACEA A5 or above. [Re: avi1777] #5187506 08/15/19 12:13 AM
E
edyvw Offline
E
Use ACEA A3 or C3.
What is overkill? HTHS of Mobil1 5W30 EP is 3, PP Euro L is 3.5. That is the most important thing for turbo application.
Also, PP Euro L is approved against MB 229.51, which means much better deposit control, NOACK limited to max 10% (PP Euro L is GTL based, so in 5W30 application NOACK is probably in range around 7%. BMW TPT 5W30 that is made by SOPUS has NOACK 6.8%. Some argue that PP Euro L is actually same oil as BMW TPT 5W30). So, I am not sure you can characterize lower NOACK, deposits etc. as "overkill."
On top of that, PP Euro L in Wal Mart is $22 for 5qt, while Mobil1 5W30 EP which is ACEA A5 is $25.
