Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
104 registered members (atikovi, abspare, Astro14, Alfred_B, billtrev, BeerCan, 13 invisible), 2,129 guests, and 16 spiders.
Topics302,038
Posts5,207,872
Members70,825
Castrol Edge 5w40 in a 3.7 Jeep #5183239 08/09/19 09:25 PM
H
HoosierJeeper Offline OP
H
Getting ready to do an oil change on the Liberty tomorrow. Saw some Castrol Edge 5w40 on the shelf at Walmart and it got me thinking, would that be a good choice? It has just over 200k on it. I’ve owned it basically it’s whole life and I’ve always run one of major brands of Dino in it, 5w30 and used high mileage stuff for the past few years. It leaks (and probably burns a little, but never see a puff of smoke on start up or after idling it) about a quart per 1-1.5k. 95% of its driving is highway (sits at one speed for a good 60 miles daily) Thoughts on the switch? Thanks!
I do plan on tending to some of the leaks over the winter when it’ll be a fun vehicle and not required to be a DD.
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183247 08/09/19 09:54 PM
O
Onetor Offline
O
Edge will serve you well. But, Castrol makes a HM 5W40 in quarts. Walmart doesn't sell it. Amazon does, but it's pricey. Original owner? "Basically it's life" is unclear?
N = R* x fp x ne x fl x fi x fc x L
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183256 08/09/19 10:09 PM
Z
zrxkawboy Online Content
Online Content
Z
I just put some Pennzoil 0W40 in ours. It seems fine...didn't notice any difference from 5W30.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183260 08/09/19 10:13 PM
J
JLTD Offline
J
Should be fine...interested in the results since I'm considering a 40 in ours.
Lates.
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183348 08/10/19 04:25 AM
dave1251 Offline
It should work well may or may not help with the consumption.
don't use.
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183371 08/10/19 05:31 AM
demarpaint Offline
It should be fine.
God Bless Our Troops
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: Onetor] #5183376 08/10/19 05:40 AM
dlundblad Online Happy
Online Happy
Do you 10w40 HM?
I’ve not seen a 5w40 HM yet. Sounds like a nice oil though.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: Onetor] #5183394 08/10/19 06:17 AM
H
H
Got it when it was 2 years old, had about 36k on it. So basically new in my book after 200k and 12 more years!
Does anyone think it’d be bad to switch to a full synthetic at this point?
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183404 08/10/19 06:43 AM
G
GMBoy Offline
G
Why a 40wt? Modern oils, especially synthetics, don't break down and fall out of grade like old oils did. I do not see the need or benefit of a thicker oil in this case. I personally would stick with a 5w/30 or 10w/30 high mileage synthetic.
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: GMBoy] #5183447 08/10/19 07:33 AM
dave1251 Offline
Just plain wrong. ISLAC 30 grades shear out of grade. It doesn't matter if it is "synthetic" this has been the case for decades.
don't use.
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183448 08/10/19 07:38 AM
G
Gasbuggy Offline
G
Try it. That's a healthy oil burn rate.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5183458 08/10/19 07:54 AM
Snagglefoot Offline
I finally joined the thickie club and am using 5w40 made by Citgo in a 2008 Chev 6.0 with 185,000 miles. The 185,000 miles was with synthetic 5w30 of various brands. The hot idle oil pressure has increased by a few psi and is still in the high 30’s. The cruising oil pressure is unchanged at 40 psi. I have a jug of Mobil 1 Turbo Diesel Truck on tap and then a couple of jugs of Penzoil Platinum Euro 5w40 ready. This magical 6.0 still doesn’t consume oil. (Knock wood). laugh
If you want the job done right......do it yourself.
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: dave1251] #5183602 08/10/19 11:46 AM
Snagglefoot Offline
We should be able to prove this one way or another with our extensive collection of UOA’s on this forum. smile
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: Snagglefoot] #5186633 08/14/19 06:22 AM
G
GMBoy Offline
G
I agree and from what I have seen, I stand by my comment that today's oils do not fall out of grade. We have 0W/20 oils holding grade with 7000 miles+ on them. In addition, Snagglefoot has not come to the present day with his belief that all oils still shear and that synthetics are superior in many ways over conventional oils. Now, I am aware that oil will eventually wear out and shear down but nothing like days past and no reason to go to a thicker oil weight (like a 40) in preparation of oil shearing down. Very few vehicles spec 40wt oils or will benefit from them unless the vehicle has very high miles and a badly worn engine perhaps. Of course I may be wrong and am always open to learn.
Re: Castrol Edge 5w40 in a 3.7 Jeep [Re: HoosierJeeper] #5187234 08/14/19 05:32 PM
BlueOvalFitter Offline
Prior to my current oil in my trucks engine was Castrol Euro 0W40. My engine had never run as quiet as it did with that oil in it.
My next OCI will be Havoline PRO DS 5W30. If after using that oil and my engine isn't any quieter, I will go back to a 0W40.
Any good 0W40 oil suggestions?
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
