1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
75 registered members (ArrestMeRedZ, ARB1977, amblerman, 4WD, 94astro, 40w8, 3 invisible), 1,435 guests, and 74 spiders.
Topics306,081
Posts5,287,038
Members71,596
"Best" rim tape? #5183077 08/09/19 06:31 PM
B
buck91 Offline OP
B
Thoughts on rim tape? I've always held velox to be "the best" so to speak but right now I have some whatever branded nylon/plastic type in my Mavic/Dura-ace 700 wheelset. Replaced a flat today due to a cut near the valve stem and noticed the tape had shifted off center in a few places (but not where the tube failure was). For now its up and running but I was thinking about replacing those plastic strips next time its apart. Any suggestions that would top velox?
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: "Best" rim tape? [Re: buck91] #5183158 08/09/19 08:08 PM
T
Taildragger Offline
T
Stans works well, we have also been using Blue 'appliance tape' at the shop. It works great too! https://www.amazon.com/Scotch-Appliance-Filament-Tensile-Strength/dp/B007XIJVDE
Next on the list is Tyvek, it is wide so it will have to be cut to width.
For tubed applications it is hard to beat Velox.
73 Big Block, 4sp Corvette
Couple of airplanes
2019 F-150 Coyote
"Turbos on an engine is God's way of telling you it ain't got enough cylinders." Mike Skinner
Re: "Best" rim tape? [Re: buck91] #5183194 08/09/19 09:06 PM
J
JLawrence08648 Offline
J
Velox or similar, Performance Bike sells a similar product to Velox.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: "Best" rim tape? [Re: buck91] #5185802 08/13/19 10:34 AM
N
NYEngineer Offline
N
I like the 3M 8898 tape. WAY cheaper than the bike brands and it seems like exactly the same tape.
Re: "Best" rim tape? [Re: buck91] #5231092 10/05/19 12:36 PM
E
ET16 Offline
E
Do they make narrow versions? I think I would need something in 12mm.
Re: "Best" rim tape? [Re: buck91] #5232467 10/06/19 09:31 PM
U
UG_Passat Offline
U
Velox is a tried and true tape for tubed road applications
Stan's tape can stretch a bit to fit the profile of the rim
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: "Best" rim tape? [Re: NYEngineer] #5234004 10/08/19 03:36 PM
J
J
That's strapping tape but I'm not sure it will work. It may flex too much. It should be fine If wrapped twice and double wrapped but Performance of Velox is only $3-$4 per wheel and it lasts forever. If it moves in to the spike nipple heads or in to the spoke hole for a double thick wheel, the tube will pop. They using sticky strapping tape if you encounter a broken spoke you have to pull the tape off. To save a few dollars, not worth it.
Re: "Best" rim tape? [Re: buck91] #5234242 10/08/19 07:57 PM
W
Wheel Offline
W
I briefly used packing tape with the filliaments, but have switched back to velox. It works better on my road bikes (and my son's too)
2009 Subaru Legacy (N/A)
Quaker State Ultimate Durability and NAPA filter
Re: "Best" rim tape? [Re: buck91] #5234856 10/09/19 12:07 PM
Z
zzyzzx Offline
Z
Why no rim cloth?
[Linked Image from images-nitrosell-com.akamaized.net]
Re: "Best" rim tape? [Re: buck91] #5235964 10/10/19 01:49 PM
N
nthach Offline
N
I use Velox if the bike uses tube. On my tubeless road/gravel setup, I'm using Gorilla Tape. It seems to be the choice for some rims that are "tubeless friendly" but not quite tubeless ready.
Re: "Best" rim tape? [Re: buck91] #5236798 10/11/19 09:59 AM
E
E365 Offline
E
I use Gorilla tape on my tubeless setups too.
Whatever's on sale...
Re: "Best" rim tape? [Re: buck91] #5236919 10/11/19 11:56 AM
U
UG_Passat Offline
U
Gorilla tape is nice and thick, which helps take up additional space in the bead hook height, allowing the tire bead to have more of an interference fit with the hook geometry.
All of my tubeless are with Stan's rims, so I just use their tape, one layer for my MTB wheels and Cyclocross wheels
Re: "Best" rim tape? [Re: buck91] #5241517 10/16/19 03:47 PM
MrQuackers Offline
I ordered some Chinese strips on eBay for my beater Giant but got tired of waiting and just used about 6 layers of Dollar Tree masking tape. Worked. Yes, it was not double wall rim.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: "Best" rim tape? [Re: buck91] #5241658 10/16/19 06:44 PM
N
nthach Offline
N
I had to re-tape a Velocity A23 a friend built for me and he used some BS FSA wheel wrap. Since Velox tape is not recommended for these(the bead seat is tight on these), I ended up using two wraps of Kapton tape I had laying around.
