A bike I've revived from the dead, a 1997 Honda CBR600F3 has an rectifier issue. The friend/owner took it out on a ride, he was almost home but smelled smoke and the bike died a few miles later. He sent me a pic of the burned connector and while I thought it was the CDI module for the ignition going out, it looked like the rectifier for the charging system went kablooey.
Turns out it's a weak spot on these bikes, my plan of attack is to order a new rectifier pigtail from the local dealership(too bad I can't order this from Honda Cars) and install a new rectifier along with soldering on a new pigtail. He told me that the last electrical system mod he did was install a Battery Tender, I ruled it out but I've heard of stories of Battery Tenders killing electrical systems on cars.
Should I get a new OEM piece, or will one of the "upgraded" aftermarket ones - not the cheap Taiwanese/Chinese ones Emco/Dennis Kirk/Tucker Rocky/Parts Unlimited distribute work? He's getting a new battery, it seems like the USA-made Yuasa AGM lived a short life and all I can find are Taiwanese-made ones at WM/AZ/O'Reilly.
