This copy is from a updated PDS from Shell. It’s not on their website yet.
PENNZOIL PLATINUM ® 0W-20 FULL SYNTHETIC MOTOR OIL - MADE
FROM NATURAL GAS
TECHNICAL DATA SHEET
Pennzoil Platinum® with PurePlusTM Technology is a first of its kind full synthetic motor oil made from natural gas and designed for COMPLETE PROTECTION.
Performance, Features & Benefits
PurePlusTM Technology is our patented, revolutionary gas- to-liquid process which converts natural gas into a first- of-its-kind extremely high quality full synthetic base oil.
Because our base oil is made from natural gas, it is crystal clear with fewer of the impurities found in crude oil, the start for many other traditional & synthetic motor oils.
From that pure, clear base we add our high performance additives to create Pennzoil Platinum® with PurePlusTM Technology, motor oil designed for COMPLETE PROTECTION, without compromise:
CLEANER PISTONS
Keeps pistons up to 50% cleaner than required by the toughest industry standard.1 Keeps your engine cleaner than any leading synthetic oil.2
BETTER FUEL ECONOMY
Drive on average an extra 550 miles vs. a dirty engine.3
PROTECTS HORSEPOWER
Helps protect engines from loss of power.
UNSURPASSED WEAR PROTECTION
No other leading motor oil provides better protection from friction.4
2 Based on Sequence VG sludge test using SAE 5W-30.
3 Fuel economy measurements made using CAFÉ cycle under FTP75. Avg of 550 extra miles based on mixed city/highway miles and US avg of 13,476 miles driven per year with 4.1% better MPG vs dirty engine. Source: fhwa.dot.gov,2011. Follow OEM recommended oil drain intervals
4 Based on Sequence IVA wear test using SAE 5W-30.
Main Applications
Pennzoil Platinum® 0W-20 with PurePlusTM Technology is recommended for use in all vehicles requiring the use of SAE 0W-20 viscosity grade engine oils under all driving conditions.
SAE 0W-20 viscosity grade oils are commonly recommended for use in many new vehicles with modern engine technology for maximum fuel economy and performance.
Pennzoil Platinum® with PurePlusTM Technology can be mixed with other synthetic and mineral oils and is recommended for use in all vehicle applications under all driving conditions.
SAE 0W-20 may not be suitable for use in older engines so always consult your owners manual for the correct viscosity grade and performance recommendation required for your vehicle.
Specifications, Approvals & Recommendations
·Chrysler MS-6395 ·
·GM dexos1TM Gen 2 (license D10068GE014)
·Ford WSS-M2C947-A
Honda/Acura HTO-06
Exceeds the requirements of the following industry specifications
·API SN-RC and all previous categories
© SOPUS Products 2017. All rights reserved.
EXCELLENT PERFORMANCE IN EXTREME TEMPERATURES
Provides faster low temperature oil flow and protects in extreme heat.
1 Based on ILSAC GF-5 and Sequence IIIH piston deposit test using SAE 5W-30.
Page 1 of 2 Pennzoil Platinum 0W-20 Full Synthetic Motor Oil (SN/GF-5), v 1.6 09.06.2017.14.50
FROM NATURAL GAS
CLEANER PISTONS
BETTER FUEL ECONOMY
PROTECTS HORSEPOWER
Main Applications
·Chrysler MS-6395 ·
·Ford WSS-M2C947-A
Honda/Acura HTO-06
