Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
106 registered members (2010Civic, bbhero, 2015_PSD, Alfred_B, Best F100, BeerCan, 7 invisible), 2,178 guests, and 21 spiders.
Topics306,108
Posts5,286,573
Members71,586
Page 1 of 4 1 2 3 4
VALVOLINE PROFLEET 10W40 #5181650 08/08/19 03:02 AM
M
mitchellp Offline OP
M
Hi how is everyone just wanting to know if anyone out there has use this oil the VALVOLINE PROFLEET 10W40 the specifications look decent Has a crazy TBN 15.6 and nice And high viscosity 153 Going to buy it and give it ago and doing a VOA on it
Also noticed that it said not suitable for diesel particulate filter which might mean it has a decent Zinc additive pack
Check out the specs here
https://go.lupinsys.com/valvoline/h.../search_api/Profleet_10W-40-PI_Sheet.pdf
https://go.lupinsys.com/valvoline/h...1a3e3/search_api/Profleet_10W-40-SDS.pdf
https://www.valvoline.com/en-australia/our-products/heavy-duty-engine-oil/valvoline-profleet-10w-40
regards Mitch
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5181663 08/08/19 04:59 AM
dnewton3 Offline
Global Moderator
Global Moderator
Looks robust and suitable for long duration of use.
will be interested to see the VOAs and some UOAs from you.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5182172 08/08/19 03:39 PM
K
Kamele0N Offline
K
regards Mitch
ACEA E4/E7....its definitely FULL saps oil...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5182216 08/08/19 04:23 PM
R
Rollins Offline
R
There is a VOA of a similar product by a Danish guy :
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4046078/Mobil_Delvac_XHP_10W40
It may or may not be very high on Zn and P but sure expect high detergent (and SA) levels.
Also m37charlie's UOA on Delvac 1 SHC 5w-40 in an Unimog can be found in the resp.threads.
Mitch , what is the application?
Re: VALVOLINE PROFLEET 10W40 [Re: dnewton3] #5182537 08/09/19 01:21 AM
M
M
Looking forward to that VOA it’s a special order product at all the normal auto shops however there’s a truck shop not too far from my house that has it it is a fairly pricey oil At $295 AUD for 20l can also get 5 L but that is special order As far as I can see
Re: VALVOLINE PROFLEET 10W40 [Re: Kamele0N] #5182538 08/09/19 01:21 AM
M
M
regards Mitch
Nice
Re: VALVOLINE PROFLEET 10W40 [Re: Rollins] #5182539 08/09/19 01:22 AM
M
M
Yeah it is getting hard to find a synthetic oil these days that isn’t cut back DPF oilIt is for a 2.8l jeep jk crd 2010 no emissions crap it fell off 😂😜
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5182547 08/09/19 02:25 AM
K
Kamele0N Offline
K
Another good one (if you can get it there...) would be Shell rimula R6M... Its GTL synthetic...
Re: VALVOLINE PROFLEET 10W40 [Re: Kamele0N] #5182551 08/09/19 03:01 AM
M
M
Interesting looks like a decent oil as well it’s showing up on the Australian website but a quick google search I can’t find a shop that has it They make a low emissions version which I can find it at lot of shops here
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5182882 08/09/19 01:16 PM
A
A_Harman Offline
A
It's a full synthetic with a VI of 153, and KV100 of 13.2 cSt. So it's a light 40-weight, probably with not many VII's. Looks like a robust, long-drain oil.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5182977 08/09/19 03:32 PM
R
Rollins Offline
R
An extended drain UOA will be very interesting ...not many LD ACEA E4 oil are used in light-duty equipment for whatever reasons. What are the intended operating conditions / OCI ? This was VM engine with timing belt,right?
Re: VALVOLINE PROFLEET 10W40 [Re: Rollins] #5183043 08/09/19 05:29 PM
M
M
Yes it is a VM Motori RA 428 DOHC It will be used heavily off road so some highway driving some heavy sand driving and slow 4x4 work And these motors are prone to have big end bearing failure In the manual it recommends a 5w40 But thought I would go a little heavier
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5183753 08/10/19 04:58 PM
R
Rollins Offline
R
...or make a "home brew" ,even heavier. Sad to hear it..I thought the bearing issue was VM 3.0 V6 "specialty".
Re: VALVOLINE PROFLEET 10W40 [Re: Rollins] #5183960 08/10/19 10:26 PM
M
M
How do I make a custom blend
What about just running a racing oil as I don’t have any emissions stuff on my car any more and I’m just after the most protection don’t really care how much it cost https://www.penriteoil.com.au/products/10-tenths-racing-10w-40-100-pao-ester
Re: VALVOLINE PROFLEET 10W40 [Re: mitchellp] #5184072 08/11/19 07:21 AM
R
Rollins Offline
R
...by mixing oils of different visc. to achieve the desired one.
I've no idea about the use of racing oils but I am curious to see a VOA or UOA after totally off-track use.
Page 1 of 4 1 2 3 4
