CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Key FOB Will Only Open Doors
by Gebo - 02/20/20 03:47 PM
Leather Care
by Smoky14 - 02/20/20 03:36 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
35 registered members (BBDartCA, alcyon, BlakeB, c502cid, blufeb95, Astro14, 2 invisible), 1,162 guests, and 16 spiders.
Topics301,730
Posts5,201,545
Members70,763
Page 1 of 3 1 2 3
CJ4 oil still available? #5181035 08/07/19 09:57 AM
F
Fraser434 Offline OP
F
Gone are the days you could find diesel oil at any shop and didn't have to be a chemist to understand if it was safe for your engine.
I'm not convinced CK-4/SN oils are reliable for our diesel engines, I see CK-4 formulations of the same oil (ie Rotella) with less of all additive levels and now no Moly.
There's a few oils I see that are safe now:
Motocraft diesel oils I think are safe, Ford seems to agree with my assumptions, even with them carrying CK-4 Ford is adamant about 1000ppm phos.
Shaeffer 9000 5W-40 is still CJ4 (last I checked)
Harvest King, still CJ4? (made by Warren oil?)
Lucas Magnum CJ4 (and CI4)
Delvac MX (but this is Ci4... may have to look closer into this one, this oil isn't on many shelves though)
Any others out there that could be suggested?
Re: CJ4 oil still available? [Re: Fraser434] #5181075 08/07/19 10:42 AM
53' Stude Offline
I highly DOUBT CK4 diesel engine oils are weak or "not good"
If that was the case member dustyroads wouldn't be using DELO 10W30
ANYWAYS: I got tons of DELO XLE 10W30 dirt cheap at autozone as well as 9 gallons of maxlife 15w40 under $8/gallon at Wal Mart that's CJ4
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: CJ4 oil still available? [Re: Fraser434] #5181091 08/07/19 11:02 AM
W
wensteph Offline
W
I believe Rotella T5 is CK-4 but not CK-4/SN. My last UOA on this at 5K still showed 63ppm Moly.
Schaeffer 700 is CK-4 but not CK-4/SN
Re: CJ4 oil still available? [Re: Fraser434] #5181129 08/07/19 12:10 PM
Snagglefoot Online Content
Online Content
Here you go.
If you want the job done right......do it yourself.
Re: CJ4 oil still available? [Re: Fraser434] #5181159 08/07/19 12:45 PM
F
F
Thank you for your contribution.
Make all the memes you want. What does Ford Motor Company know.
https://www.flsheriffs.org/uploads/docs/January_2017_Updated_CK-4_Position_Statement.pdf
I know the intent of Ford's statement, that they don't approve having CK-4/SN oil with 800ppm max phos, and are concerned with the CK-4/SN deception. still the options are becoming very limited and expensive for 1200+ ppm Phos. oil.
Re: CJ4 oil still available? [Re: Fraser434] #5181168 08/07/19 12:54 PM
53' Stude Offline
Since you already mentioned Rural King; mine has a lot of CJ4 10W30 all fleet HDEO.
I'm still curious why you think CK4 oils aren't reliable for diesels. The Valvoline Maxlife I have has moly and boron also
161,669 miles
Re: CJ4 oil still available? [Re: Fraser434] #5181198 08/07/19 01:42 PM
H
hallstevenson Offline
H
Why aren't you ?
It's entirely possible - or likely - that the additive levels of the past were more than necessary. Maybe a LOT more than necessary. It sounds like multiple oil formulators/blenders have reduced additive levels similarly and came to the same conclusion. They aren't going to do so just because the other guys did unless it's safe to do so.
Re: CJ4 oil still available? [Re: Fraser434] #5181202 08/07/19 01:48 PM
B
BlakeB Online Content
Online Content
B
I reached out to a Chevron rep, this was their response:
[Linked Image]
Re: CJ4 oil still available? [Re: Fraser434] #5181206 08/07/19 01:55 PM
K
krismoriah72 Offline
K
Lubriguard 15w40 at Autozone CJ-4/SM
https://www.autozone.com/motor-oil-...stp-15w40-diesel-engine-oil-1gal/54319_0
*They call it STP.
Re: CJ4 oil still available? [Re: Fraser434] #5181275 08/07/19 03:46 PM
SR5 Offline
Come to Australia, I still see this stuff on sale everywhere
Valvoline Super Diesel 15W40 mineral oil
API CH-4/SJ, ACEA A3/B3
Cheap and old school
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: CJ4 oil still available? [Re: 53' Stude] #5181277 08/07/19 03:47 PM
dustyroads Offline
You're correct Adam. I've put Delo XLE (a "low phosphorus" CK-4) to the test in real world use and it has worked marvelously. However it's fruitless to say anymore. I've given up on trying to get people to understand the benefits of the new oils. Then again, not many people use their diesel vehicles in a way that pushes the oil and it doesn't matter to them. For me, CK-4 has been a true benefit to my business.
2013 F150 XLT 5.0 4X4 122k miles
Re: CJ4 oil still available? [Re: Fraser434] #5181280 08/07/19 03:56 PM
2015_PSD Offline
Too bad you are not close to Houston, I still have gallons of synthetic CJ-4 (Mobil Delvac and Chevron Delo 5W-40), I could sell to you.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: CJ4 oil still available? [Re: Fraser434] #5181281 08/07/19 03:59 PM
M
mbacfp Offline
M
Would take you up on that 2015_PSD if closer as well...now using Valvoline CK-4 5W-40 as ok per Ford's list.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: CJ4 oil still available? [Re: Fraser434] #5181383 08/07/19 05:55 PM
B
BigD1 Offline
B
Last time I looked at Rural King all fleet it was still CJ4. Not sure if it's Warren Performance Products or Warren Oil Company Dunn, NC.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: CJ4 oil still available? [Re: Fraser434] #5181450 08/07/19 06:58 PM
Online Content
Here you go. Read the label on the back. It’s CK-4 and meets Ford WSS-M2C171-F1. smile
Page 1 of 3 1 2 3
