OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
93 registered members (ArrestMeRedZ, Aero540T, avi1777, 2002 Maxima SE, 55hambone, 9 invisible), 2,220 guests, and 17 spiders.
Topics301,824
Posts5,203,434
Members70,787
10w30 four stroke oil #5181088 08/07/19 10:56 AM
M
minnowhooker Offline OP
M
Have a Honda 135 600hrs looking for a easy to find 10w30. Manual says Honda oil or API-SG,SH,SJ oil.
I used Quicksilver this year but read on this site that it's not as good now because it's now approved for catalytic converter motors, less shear additives..........to much info on this site.
Something with a least 3.3 hths which I read you need for shear on 4 strokes......guess where I seen that?
Only thing I could find with SJ rating is Castrol 10w30 at Walmart, could not find hths on it but I read 5w30 had 3.1 and they guessed 10w30 was a least 3.3.
Or 10w30 rotella but I winter fish with water temps sometime middle 30's didn't know if to thick?
Not much conventional oil rated SJ that I could find......Thanks
Re: 10w30 four stroke oil [Re: minnowhooker] #5181113 08/07/19 11:33 AM
A
ad244 Offline
A
I too was a Quicksilver fan....
Supertech has their own 10w-30 but honestly, the Honda GN4 is so inexpensive and really great stuff that Honda engines seem to like:
https://www.amazon.com/gp/product/B...;linkId=0db31da62f2f538cc0042b23442d2e4c
https://www.amazon.com/gp/product/B...;linkId=5b71659c5a96939c41e2c4f9fc0473ea
Re: 10w30 four stroke oil [Re: minnowhooker] #5181158 08/07/19 12:44 PM
B
bubbatime Offline
B
Cheap and easy to find. Delo synthetic blend 10W30. Its dual rated for diesel and gas engines.
[Linked Image]
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: 10w30 four stroke oil [Re: minnowhooker] #5181182 08/07/19 01:13 PM
O
Oro_O Offline
O
Originally Posted by minnowhooker
a) , could not find hths on it but I read 5w30 had 3.1 and they guessed 10w30 was a least 3.3.
b) Or 10w30 rotella but I winter fish with water temps sometime middle 30's didn't know if to thick?
a) I would not bet on that. Lots of places that do give specs, the 5w30/10w30 are often not different in HTHS.
b) a lower winter rating won't flow any better at that temperature. Differences show up much lower at colder temps. 10w-30 is a better choice if you are operating an engine over 15/20F mostly. Go with 10w-30. It will be the same viscosity at middle-30s temperature on starting.
I don't know why an SN oil wouldn't work? I imagine the manual says that (SJ) as that was the spec when it was made (presuming this is an older 135 and not brand new). I use Mobil 1 10w-30 HM (in cars) as I know the HTHS is 3.5; maximum for a 10w30. If you really want 3.3 HTHS minimum, don't just assume a major label 10w-30 will do it. For example, the non-HM Mobil 1 10w-30 is 3.0 HTHS (and the 5w-30 is 3.1). Usually only hot-rodders care about SJ vs SN.
I think the M1 bi-annual rebate is on right now, so it's also cheap as well as everywhere.
Re: 10w30 four stroke oil [Re: minnowhooker] #5181205 08/07/19 01:51 PM
K
krismoriah72 Offline
K
Here is a good thread on your topic... (i would go with T5 10w30 or Delo XLE 10w30).
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4244992/all/cheaper-fc-w-oil
Re: 10w30 four stroke oil [Re: minnowhooker] #5181223 08/07/19 02:36 PM
dave123 Offline
Amsoil ASE 4stroke small engine oil checks every box you’re looking for.
Re: 10w30 four stroke oil [Re: dave123] #5181239 08/07/19 02:56 PM
K
kschachn Offline
K
Except for the part about being API SG, SH, or SJ, at least not per the API EOLCS directory.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: 10w30 four stroke oil [Re: minnowhooker] #5181293 08/07/19 04:17 PM
M
M
All good recommendations, I'm curious about Mobile 1 HM the hths sounds great but I read something about KV's being low don't flame me if I get abbreviations wrong but if that is so would it be compatible with 135hp it is a 2009 model............. I read that here researching oil......Thanks
Don't know if that even matters
Re: 10w30 four stroke oil [Re: kschachn] #5181368 08/07/19 05:35 PM
dave123 Offline
. Spec sheet meets SL SJ SG JASO MA
Re: 10w30 four stroke oil [Re: dave123] #5181393 08/07/19 06:02 PM
K
kschachn Offline
K
It does? You and I must be looking at different spec sheets then because what I see is that it says "Use the appropriate viscosity of Synthetic Small-Engine Oil in applications that require any of the following specifications:" That's a bit different than saying it meets the licensing requirements.
I don't consider that to be ambiguous at all, it may be a great choice for the OP but it is not API SL, SJ, or SG or else it would appear on the API EOLCS listing. They also have not filed the MA listing with the JASO Engine Oil Standards Implementation Panel, although they are not necessarily required to do so.
1994 BMW 530i, 251K
Re: 10w30 four stroke oil [Re: kschachn] #5181401 08/07/19 06:10 PM
dave123 Offline
I don't consider that to be ambiguous at all. I wouldn't even have brought it up had you not said it "checks every box you’re looking for" when in fact it did not. May be a great choice for the OP but it is not API SL, SJ, or SG. They also have not filed the MA listing with the JASO Engine Oil Standards Implementation Panel, although they are not necessarily required to do so.
For crying out loud we’re going that path that oil is about as tough as it gets you run what you like ASE is as stout of a oil as it gets. AND CHECKS EVERY BOX!,
Re: 10w30 four stroke oil [Re: dave123] #5181408 08/07/19 06:13 PM
K
kschachn Offline
K
Except for the part about being API SG, SH, or SJ. Why is this so difficult when it comes to this brand of oil? Why does everyone want to make it out to be something that it is not? If it's a great oil then sell it on the other attributes it does have rather than always trying to say it carries approvals and certifications it does not have.
If certifications and approvals don't matter then tell us what does matter and what substitutes for them.
1994 BMW 530i, 251K
Re: 10w30 four stroke oil [Re: minnowhooker] #5181629 08/07/19 11:40 PM
SteveG4 Online Content
Online Content
Valvoline makes 4-stroke motor oils for ATV's, UTV's and motorcycles.
Both the conventional and synthetic below meet or exceed the user's requirements, stating those exact same reqs.
VALVOLINE™ 4-STROKE MOTORCYCLE OIL:
https://sharena21.springcm.com/Publ...bd3/15856626-53bb-e711-9c10-ac162d889bd3
VALVOLINE™ 4-STROKE FULL SYNTHETIC MOTORCYCLE OIL:
https://sharena21.springcm.com/Publ...bd3/1133c41e-92bb-e711-9c12-ac162d889bd1
One or both types are available on Amazon.
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: 10w30 four stroke oil [Re: minnowhooker] #5182278 08/08/19 04:43 PM
M
M
Everybody........Thank You for your recommendations I will use one of these oils.
Re: 10w30 four stroke oil [Re: minnowhooker] #5189711 08/17/19 03:14 PM
M
M
Went with this good price and free shipping on orders over 75.00...........I just ordered two years worth my takes 7 quarts a change and a dollar something cup to get to 75.00
https://www.rockymountainatvmc.com/parts/pro-honda-gn4-4-stroke-motor-oil-p
