Originally Posted by PWMDMD
Originally Posted by Danh
Originally Posted by dave1251
Originally Posted by skyactiv
Read the bottom paragraph.
I wish the OEM attempting to deny a warranty using this the best of luck. About the only way that argument is flying if someone used a 70 grade in the artic then immediately floored it after engine start.
I think the point here is that, if the OEM decided to be difficult (and there's no guarantee they would) they could produce an engineer at arbitration with all kinds of data showing 0w-40 was harmful to the OP's engine. Perhaps this would be wrong or poorly founded but how would the OP counter? Hire his own engineer and tribologist? The safest path is to follow the manual during warranty and not give the OEM and easy out.
The only reasonably likely oil-related failure in an engine is failure due to lack of oil volume. Assuming the oil meets the correct certifications I don't think an engineer can produce data that conclusively shows putting 5W-30 or 0W-40 in an engine spec'd for 0W-20 can cause failure....because I don't think it can...as in it's not physically possible. At least not legitimate data...and to think a manufacturer is going to manufacture false data to not pay a warranty repair is crazy.
It would be almost impossible to negate a claim based on the owner using what's on the oil cap. That's just plain silly. And to go a step further, their chart shows 5w20 and 5w30 on the same temperature range.
