I just picked up a cheap 3rd rig for mountain and fishing use. It's a 1997 GMC Yukon that's lived its entire life in the high desert. It came from the family that bought it new. It had 105k miles in its first 9 years, then only 60k over the last 13. It hasn't been used to tow anything more than a pop-up, the seller says, and doesn't appear to have been abused. (It was still being garaged.)
The owner says he did a tranny pan drop and put a new filter on about 5k miles ago. I don't have a clear indication of what kind of ATF service he'd done prior to that, if any. The ATF looks pretty good and still has a pretty strong additive smell to it. For a truck with 167k miles, it seems to shift pretty well.
As I go through it with things like fuel filter, brakes, PCV valve, gear oil, etc., I'm wondering if I should do anything to the transmission. My usual move with a new-to-me used vehicle is to drop the pan, install a new filter, add a drain plug and do a few drain/fills until the fluid looks like new. I look at it as a pretty cheap way to add life to the car. That said, I've also heard stories about opening a can of worms when adding new fluid to an older transmission.
Any advice? What would you do?
For those saying drop the pan, what fluid would you recommend? MaxLife? Dexron III? Dexron VI?
Thanks a lot.
Thanks a lot.
