Hi guys,
The families boat has a 4.3l cobra I/O and all of a sudden will not turn over.
The battery is new and fully charged, accessories work....the ignition switch and tether cutoff both work fine. I've jumped them both with the same result.
Theres power getting to the engine, because I hear the whine of what appears to be an oil or fuel pump.
There is NOTHING getting to the starter. Fuses are all fine, as are the breakers (newer 4.3)
Could this be a starter or starter solenoid issue? Strange the boat has been flawless until it quit completely.
Any thoughts are appreciated.
