Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
81 registered members (55hambone, 4WD, 2strokeNorthstar, AC1DD, 01VFR, 2013ecof150, 8 invisible), 1,569 guests, and 19 spiders.
Topics301,809
Posts5,203,123
Members70,784
2019 L5P Duramax Rotella T5 15W-40 #5179544 08/05/19 10:45 AM
W
wensteph Offline OP
W
Not yet decided on OCI for this truck. My age and how much I still want to crawl underneath one is certainly a factor. If I go a longer interval the Rotella would be a better candidate than the Delvac. While the L5P only shares a name and displacement with predecessors it looks to be as easy on oil. Current fill is Schaeffer's and after that I'll do a run with ST.
Attached PDF document
Re: 2019 L5P Duramax Rotella T5 15W-40 [Re: wensteph] #5180072 08/06/19 03:58 AM
dnewton3 Offline
Global Moderator
Global Moderator
Being so young, there's break-in residual still left, but it is clearly coming down. Don't worry about the Cu; it's from the oil cooler and will settle once fully oxidized - it will chelate until it's fully seasoned.
I can tell you that, at a very minimum, you should follow the IOLM. If you are intent on continuing UOAs, then let them be your OCI guide. It is typical for a Dmax to have low wear rates, and actually continue the downward trend of wear out to 15k mile OFCIs. I have seen no distinguishable differences in wear rates from any of the 5 gens of Dmax; from LB7 to the L5P, they all wear about the same (which is to say excellent).
The very few poor Dmax UOAs I've ever seen have been from massively abused or altered engines; not unlike the guy recently whom put a improper CAT filter on (having no BP feature) and then thickening his oil to a 50 grade with Lucas; that didn't end well in the wear category ...
Just run a 10w-30 or 15w-40 HDEO conventional oil and follow the IOLM (or further); it'll be fine. Nearly 600 UOAs cannot be wrong; that's how many I have for the Dmax series of engines. Data don't lie.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2019 L5P Duramax Rotella T5 15W-40 [Re: wensteph] #5180236 08/06/19 09:43 AM
W
wensteph Offline OP
W
I've always been in agreement with your opinions on this engine. In my first post with this truck I noted that there was only a single prior UOA on the L5P so I intended to cycle through several oils just to add to the database since the engine is different internally from all the other DMaxes. Regardless of the differences it looks like the L5P is falling in line.
I posted a UOA on the free dealer fill which was Delvac. This fill was T5 on a Walmart rollback with rebate. Current fill is Schaeffer at retail to sample a 'pricey' oil and I'll sample that one out beyond 5K. After that probably ST to cover all the price points.
Re: 2019 L5P Duramax Rotella T5 15W-40 [Re: wensteph] #5181665 08/08/19 04:04 AM
dnewton3 Offline
Global Moderator
Global Moderator
Not only does the Dmax turn in great UOAs, but it also exhibits absolutely zero preference for lubes. Buy the least expensive qualified HDEO you can find and rest well at night.
