m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
57 registered members (ammolab, bbhero, Aero540T, ArrestMeRedZ, apollo18, 4 invisible), 1,566 guests, and 47 spiders.
Topics298,352
Posts5,133,567
Members70,043
Most Online3,589
Nov 2nd, 2019
Educate me: what's the point of a remote filter? #5178846 08/04/19 12:39 PM
SnowDrifter Offline OP
So since the fluid is sucked first through the transmissions internal filter then passed through the cover, which is where a remote filter would be mounted. What's the point of it? Seems the fluid would be filtered before it gets filtered
I may or may not look into installing one. Want to see the best life out of my components but I also don't want to ibtroduxt more failure points and throw away money, know what I mean?
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5178865 08/04/19 01:13 PM
A
atikovi Offline
A
Does the remote filter replace the one in the pan? If so, fluid and filter changes are much quicker and easier with a spin on remote filter.
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5178907 08/04/19 02:11 PM
R
Rand Offline
R
usually the in pan filter is just a rock-catcher, spin on filters catch much more.
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5178949 08/04/19 03:45 PM
Cujet Offline
The details are in the specifications. Many transmission filters with polyester media are 160++ micron rated. In other words, near zero restriction to flow at any temperature.
By comparison, external filters can be 10 micron rated or less, with very high efficiency.
And of course, there are always the submicron bypass type filters.
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5179103 08/04/19 07:35 PM
So then the question becomes, what is the appropriate way to size a filter at a given micron rating? Or how would one determine the flow rate through the cooler?
2005 Tahoe - 140k
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5179470 08/05/19 09:07 AM
Researching further, it seems the most appropriate would be to install a rather low micron rated filter on a housing that has its own internal bypass valve.
Problem is, my keywording is terrible and I'm having difficulties finding such a housing. Does anyone have any resources? Trying to find one in the 5 to 10 psi range
2005 Tahoe - 140k
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5181162 08/07/19 12:48 PM
L
Linctex Offline
L
I use a filter base/housing for a Log Splitter hydraulic system..... it's EXTREMELY generic - - - about as common as the good 'ol FL-1A or PH8A
A Baldwin BT839-10 (10 micron) is on there (the RED one) - it'll last the life of the vehicle!
[img][Linked Image][/img]
Re: Educate me: what's the point of a remote filter? [Re: Rand] #5184584 08/11/19 07:09 PM
dave1251 Offline
And with Rock catchers the transmission usually fails I don't know after the automobile is junked.
don't use.
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5199392 08/28/19 09:54 PM
TheLoneRanger Offline
Virtually all spin-on filters have a bypass valve, as does the Magnefine. This eliminates the danger of clogging. You determine the flow rate through the cooler circuit by running a hose into a
bucket and timing the flow with the engine running. For instance, the flow rate for a Jeep AW4 cooler circuit is 3/4 quart per minute. The flow rates for spin-ons and Magnefines are many times
greater than what's needed in transmissions.
Some days you eat the bear, some days the bear eats you.....
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5275425 11/23/19 12:17 PM
P
Pyrotechnic Offline
P
The Donaldson Hydraulic Catalog has all information you want.
https://www.donaldson.com/content/d...G/Hydraulic-Filtration-Product-Guide.pdf
Take a look at the SP15 series. The mounts and filters use a 1"-12 thread that is very common (like Linctex mentioned). This style of mount/filter is used on a lot of medium duty truck applications for an external transmission filter.
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5276970 11/25/19 10:38 AM
sdowney717 Offline
Many transmissions today do not have a user serviceable pan and filter. Filter is only replaceable by splitting the entire transmission case apart. So a separate filter could be useful to extend the life of the deeply buried internal filter. Vehicle manufacturers consider such transmissions as good for the life of the car, and some you cant work on at all without taking it all apart.
They even consider fluid good for the life of the vehicle, so make it tough to change or add any.
Re: Educate me: what's the point of a remote filter? [Re: SnowDrifter] #5280892 11/30/19 06:56 AM
E
Excel Offline
E
I dont see why anyone needs more than a pan filter unless your doing some endurance [censored] or have a tranny burning parts up
2015 Ford F150
2015 Ford Mustang GT,Whipple powered
2017 Yamaha FZ09
Re: Educate me: what's the point of a remote filter? [Re: Excel] #5283499 12/02/19 10:33 PM
O
OLEJOE Offline
O
How about if you're putting 1000ft.lbs. of torque through the input shaft? Towing cross country with a trailer? Trying to keep a $60-70,000 dollar vehicle maintained.
Jack of All Trades. Master of some.
