Ford Racing 820 cut open
7K miles logged on oil and filter
As you can see the Ford Racing is basically a heavy duty
Purolator from the stand point of the base plate and can.
2018 F250 6.2L
Used Chevron XSP 5-30
Replaced it with a Fram XG-2
Rotella Gas Truck 5W-30
Originally Posted by kstanf150
2018 F250 6.2L
Looks good, thank you for c&p
2018 F250 6.2L
It's a well made filter as far as built for abuse
The base plate and can are heavy and thick
Just cost to much for a daily driver
But if anyone has a hi performance car or track car that needs a HD filter this filter will serve you well
2018 F250 6.2L
Very welcome sir
Thank you for something that the forum doesn't see everyday.
Bigger string but still a string
Do you have efficiency ratings?
I would assume its low efficiency.
I'll look back at some sites I've reviewed
I remember see that info, so I'll dig around
Surprised at the ADBV. Must be a "Racing" filter not a RACING filter
I'm glad you brought that up
I was starting to get cold start valve noise in the mornings and after feeling how soft and thin the ADBV was. I'm pretty sure it was due to the fact it's just not made to be a daily driver filter
They are 99% @ 20μ. The flow vs delta-p graph is a bit higher than a PureOne, so the media is probably pretty similar since it's made by Purolator.
Thank you for the info ðŸ‘
Here's the spec sheet. It's old (April 2005), but the current filters are probably the same in performance.
[Linked Image]
[Linked Image]
Exactly the chart I was looking for
Thanks again ðŸ‘
Originally Posted by 69Torino
Same filter I use on my Marauder. Looks good, thanks for posting it up.
Your welcome sir
Good to hear from you !!ðŸ‘
