The wife bought a ‘19 Lincoln Nautilus Select AWD with a 2.7 boost. So far it's a nice car, reminds me of a Mazdaspeed3 that's gone to finishing school, a real good finishing school. Its larger of course but with the 8 speed trans and AWD it's fun to drive and has good acceleration. For her it's fine, she misses our ‘08 Speed and this kinda erases any regret.
Oil changes shouldn't be bad, typical 2.7 routine. I was dreading servicing the PTU as this thing can be a bit of a wicket to change oil on. Sifting the web with this in mind I ran across this:
https://markets.businessinsider.com...us-for-global-ford-crossovers-1026837821
If I read this correctly this is a new AWD system that doesn't even spin the drive shaft going aft until AWD is called for, unlike the PTU on the ‘18s and earlier which looks a small ring and pinion assembly that drives the rear drive shaft at all times. Hopefully it won't have the old style PTUs maladies- leaks, over heated lubricant and a general nature to come unraveled.
I hope bdcardinal will chime in on this; in a recent discussion here to change oil on my new PTU I'll have to remove cooler lines. Hopefully this new design won't be so "close to the edge" durability wise and may even look like some sane engineering went into it. AAM apparently has had the first gen of this system installed in some Jeep models for several years. Any Jeep enthusiast ( or anybody else for that matter ) care to chime in with their experience with the thing?
Thanks guys!
Thanks guys!
