I've tried a few different coils on the market just because. At least on my vehicles with points, I need a 3Ω coil. The generic Duralast branded 3Ω coil I bought from Autozone when I had one die within walking distance of a store has worked as well as any Bosch, Mallory, or Pertronix branded coil I've tried. The Pertronix "flamethrowers" SEEM the highest quality, but at the same as said the coil will only fire as much as is required to jump the spark plug gap(as a side note, the gap does affect this voltage a lot, but the pressure inside the cylinder, A/F ratio, and even humidity-to a small degree-affect it also). As a hedge against failure, I just carry a spare in the trunk-also a tested and known good Duralast one.
Also, this may be even more controversial than points replacements like Pertronix, but I run a Winterburn CDI module on my MG. It's triggered by the points, but there's essentially no electrical wear on them because the contacts only make/break ~12V with a small amount of current(typical Kettering type ignition will see ~300V on the points). That system lets me open my plug gap up to .035 for a much "hotter" spark, and fewer misfires. A year and a half after installing it, the jury is still out as to whether it improves power and MPG perceptibly
, but at least I don't have to worry about the points anymore.
One last thing-I ran Pertronix for a while, although I used a complete Pertronix brand drop-in distributor(in a Lucas 25D4 casting in my case). In retrospect, I'd have been better off with the original/rebuilt distributor with a Pertronix module fitted, as the quality of the new production complete distributor was not great. Although the car always started and ran fine with it, I was always afraid of things like the fact that you can fry the Pertronix module if you leave the ignition hot without the engine running. The newer Ignitor II and III are supposed to cure that(plus add some other more advanced features) although at the time those weren't available for my car.
