My 14 dart gt got new nokian all season tires 4,000 miles ago. The inside edge of both rear tires is already starting to be feathered. The alignment was done when the tires were replaced they didn't adjust the rears because they said the rest checked out and was in spec tire pressures are at 40 even the place card says 36/38 I believe. The suspension is all right the car has 72,000 miles the shocks are dry. What do you guys recommend?
