Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
DTD Frustrating Website Change
by ctechbob - 05/26/20 02:17 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
25 registered members (Bjornviken, anndel, BlakeB, bworley, Boxnuts, Char Baby, 4 invisible), 1,083 guests, and 54 spiders.
Topics305,882
Posts5,281,992
Members71,528
2007 CRV Air Conditioning Issues. Hottest days, it cuts out. #5175924 07/31/19 04:52 PM
G
Gasbuggy Offline OP
G
I will preface this by saying I am no stranger to sorting out issues, but not so much with Air Conditioning. This A/C will work perfectly most of the time, but it seems that when it gets really hot out the compressor shuts off entirely. Once things cool off a little, or on the first ride of the day, it works fine. After the engine gets heat soaked, it's more likey to happen. My mother has been driving this car for several years, since 15,000 miles, currently at 117,000.
I have checked to make sure it is not a relay issue, a undercharge/overcharge issue, fan cooling condenser issue,I also cleaned the condenser. My parents took it to their mechanic and my information I guess didn't get past the desk girl so they put dye in the system and charged $125. Excellent. The system didn't need to be charged and wasn't leaking.
Anyone have thoughts on this issue?
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5175929 07/31/19 04:59 PM
T
The_Nuke Offline
T
So does the compressor clutch refuse to engage in extreme ambient temps or does it engage as expected but immediately shuts back off?
My first thought is that it sounds like it's overcharged, but that's merely an educated guess based on limited information.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5175934 07/31/19 05:09 PM
G
Gasbuggy Offline OP
G
Refuses to engage.
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5175938 07/31/19 05:15 PM
J
JeffKeryk Offline
J
There is a problem with CR-V AC in those years.
It can be a out-of-spec clutch; there is a maximum air gap.
One test is to tap it with a hammer to see if it engages.
I had to replace the entire system on a 2006 CR-V; hopefully your problem has a simpler fix.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5175942 07/31/19 05:18 PM
Chris142 Offline
Does this car still have the OE condenser?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5175948 07/31/19 05:23 PM
G
Gasbuggy Offline OP
G
I read about an issue with the compressors self-destructing. I'm seeing alot of people around here driving their CR-V's with the windows down.
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Chris142] #5175950 07/31/19 05:25 PM
G
Gasbuggy Offline OP
G
Yes, it does. Everything is oem
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5176026 07/31/19 06:49 PM
Snagglefoot Offline
I’m betting on the compressor clutch. The clearance Is too large due to wear and when heat soaked is not engaging. A new compressor might be in order.
If you want the job done right......do it yourself.
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5176029 07/31/19 06:55 PM
N
Nukeman7 Offline
N
Here is your answer...too bad it is beyond the extended warranty. I'd still see if Honda might do a goodwill repair, however unlikely.
Honda TSB 12-072
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5176084 07/31/19 08:07 PM
G
Gasbuggy Offline OP
G
Nukeman, thanks for the link! I doubt they'll do it. I've replaced a clutch assembly once. I will print this out and let their mechanic take care of it.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5176086 07/31/19 08:10 PM
T
Trav Offline
T
Start with the cheapest things first, check for power and ground, cost = zero. The Honda A/C relay is notorious for failure when hot, jump the clutch, if it engages that is probably not the problem.
Nothing sucks more than doing a bigger and expensive job just to find out you still have a problem and it was a cheap easy to replace part in the first place.
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5176121 07/31/19 08:49 PM
N
Nukeman7 Offline
N
You might want to tackle it yourself if Honda refuses to help. I have had luck by just removing the front armature plate and deleting one of the thinnest shim washers to decrease the clearance gap. You may also try sanding the backside of the armature plate with emery cloth to get a smoother mating surface. Worst case, buy a cheap replacement A/C clutch from ebay and just change out the worn armature plate. No need to replace the magnetic clutch coil which is the difficult part of the job. Just be sure to not lose any of the shim washers.
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5176254 07/31/19 11:58 PM
1
14Accent Offline
1
If it needs a clutch, just replace the compressor. The thermal cutout switches on those compressors are finicky, as well, and will cause a loss of clutch engagement. As you've seen, that compressor may be a ticking time bomb at that mileage. I have yet to have an issue with an aftermarket unit on a CR-V, just make ABSOLUTELY sure to drain the oil out of the new compressor into a container and do the same for the old one, adding back what you got out of the old into the new (with the new oil, of course). Those system's absolutely hate being overfilled with oil and won't cool well at all with as little as 2 oz too much.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 2007 CRV Air Conditioning Issues. Hottest days, it cuts out. [Re: Gasbuggy] #5176345 08/01/19 06:45 AM
K
klt1986 Offline
K
Went through the same thing last year with my wife's 2008 CR-V. Wound up replacing the compressor as it turned out not to be the relay. Local dealer said they used to do a lot of them and were surprised mine had lasted. The extended warranty had expired on mine as well.
