Hopefully someone with more knowledge of central air conditioning can help with my situation.
The system has been working fine this cooling season, until now. When leaving the house this morning, I noticed a humming noise coming from the outside compressor of my first floor central air conditioning system. The condenser fan was not spinning and I thought that the noise might have been from a seized fan motor. But the fan rotated freely when I nudged it with a stick.
The humming noise was quite low in volume. Periodically, it would get louder for a few seconds, then return to the lower volume for 20-30 seconds before cycling to the higher volume again. During this time, the interior blower motor was running, but the condenser fan was not spinning. I turned the system off and left for my meeting. When I returned roughly 5 hours later, I tried the ac again via the thermostat and got the same results. Low humming with short intervals of louder humming.
The compressor unit is a Goodman model CLT 30. It has been in service for 16 years. I have a photo of the info plate if that will be of any assistance. The second floor compressor is also a Goodman (slightly smaller) and is currently operating well.
Can anyone offer any guidance for trouble shooting this system? I am generally pretty good at diagnosing and fixing things, but this is a little outside of my comfort zone. I do not have any refrigerant system manifold pressure gauges, but I do have a multi meter if there are any electrical tests that I should run. My initial guess is that the compressor is seized up for some reason. This could be refrigerant related, or it may simply have worn out. Also, I have noticed this season that when the compressor activates the noise seems to be louder than in past years. I didn't think much of it at the time, but the issues may be related. Cooling wise, I haven't noted any difference this year from previous years.
I would appreciate any assistance that you can provide.
