How do you properly diagnose this issue? I would rather try and diagnose it myself, but may have to have a shop do this.
My 2002 Ford Ranger Edge 3.0L 67k original miles will shudder as low as 30mph on up to 65mph. It feels as if I'm driving over rough road or there is a misfire in the engine. I have pretty much ruled out the engine because I did a compression test and it was fine. I had my local shop do a full diagnostic and fuel trims came back good as well as no vacuum leaks. I replaced the plugs, plug wires, coil pack and cleaned sensors which did not help the shudder. So now I'm pursuing a possible converter issue.
As noted in prior threads, no CEL or codes.
