Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
109 registered members (abspare, Astro14, bdcardinal, Bailes1992, 53' Stude, avi1777, 10 invisible), 2,102 guests, and 14 spiders.
Topics302,038
Posts5,207,853
Members70,825
Page 2 of 4 1 2 3 4
Re: Same DEXOS approval number for several brands? [Re: 21Rouge] #5181760 08/08/19 07:18 AM
R
RyanY Offline OP
R
Originally Posted by 21Rouge
Originally Posted by RyanY
(Is this the definitive dexos list as quickly looking through these oils I see one and only one 0W30 that has dexos1 Gen2 approval and that is an M1 offering).
Apparently the only currently approved 0w30 is M1. I dont have access to the dexos gen 1 list (if one ever existed) so I can't tell whether others were approved at that time. Do any newer GM cars spec 0w30?
2007 Cadillac CTS 3.6L >129k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >106k miles; STP (Amalie) 0W20 + ACDelco PF2057
Re: Same DEXOS approval number for several brands? [Re: RyanY] #5181772 08/08/19 07:33 AM
K
kschachn Offline
K
Does GM "spec" any grades or are they recommendations?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Same DEXOS approval number for several brands? [Re: RyanY] #5181781 08/08/19 07:45 AM
Snagglefoot Offline
I believe the Citgo made oils all end with 121. The re-packaged oil also ends with 121 and includes Blaine’s Farm and Fuel, Harvest King, Master Mechanic, Motomaster ( Canadian Tire’s house brand up in Canada), and Resolute.
Another interesting observation is the code for Napa products in the USA is 103, same as Valvoline.
Supertech, STP and Amazon Basics all end in 25, which is Warren Distribution.
Thanks for posting the updated list. smile
If you want the job done right......do it yourself.
Re: Same DEXOS approval number for several brands? [Re: Snagglefoot] #5181952 08/08/19 10:45 AM
B
bbhero Offline
B
STP full synthetic also made by Amalie that ends with 49. HG049 in fact.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Same DEXOS approval number for several brands? [Re: kschachn] #5182010 08/08/19 11:45 AM
R
RyanY Offline OP
R
Good question! I may be mistaken and/or reading too much into this, but my understanding is that a specification indicates a "must use" oil whereas a recommendation indicates a "should use" oil.
Based on this interpretation, my 2007 Cad owner's manual appears to be somewhere between a recommendation and a specification. Under the heading "Recommended SAE Viscosity..." it indicates 5w30 but then directly states "Do not use...any other viscosity grade oil not recommended." Is this a recommendation or a specification?
Regardless, given that GM4718M is outdated, my interpretation is that I should use 5w30 dexos approved oil even though other viscosities also have dexos approval.
Re: Same DEXOS approval number for several brands? [Re: Snagglefoot] #5182083 08/08/19 12:52 PM
53' Stude Online Content
Online Content
Harvest King is now WARREN OIL, not Citgo anymore
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Same DEXOS approval number for several brands? [Re: RyanY] #5182238 08/08/19 03:39 PM
G
Garak Offline
G
GM has, for the longest time, traditionally permitted 0w-30 in 5w-30 applications where useful for the weather conditions. They've had the wording in the manuals for many years.
Plain, simple Garak.
Re: Same DEXOS approval number for several brands? [Re: Garak] #5182314 08/08/19 05:32 PM
R
RyanY Offline OP
R
I was not aware of that...thanks! I never checked this, as I probably wont need 0w30 in my region.
Re: Same DEXOS approval number for several brands? [Re: RyanY] #5182391 08/08/19 06:59 PM
G
Garak Offline
G
Just from a quick check, here's the wording for the 2019 GMC Terrain, which is the similar wording to what I've seen for years:
Quote
For the LTG 2.0L turbo engine, use SAE 5W-30 viscosity grade engine oil. Cold Temperature Operation: In an area of extreme cold, where the temperature falls below −29 °C (−20 °F), an SAE 0W-30 oil may be used. An oil of this viscosity grade will provide easier cold starting for the engine at extremely low temperatures.
Re: Same DEXOS approval number for several brands? [Re: RyanY] #5183555 08/10/19 09:58 AM
2
21Rouge Offline
2
And yet it it appears Castrol Edge 0W30 has dexos 2 certification (and not listed in the latest approval list)
[Linked Image]
Re: Same DEXOS approval number for several brands? [Re: JimSilverado] #5183557 08/10/19 10:03 AM
dave1251 Offline
Originally Posted by JimSilverado
I have an 2018 Silverado. Purchased new. Used up the 2 free oil changes at 5,000 miles each. Currently Running Rotella T6 15-40W. No issues
Why would you have issues? But 15W40 is not what I recommend using.
don't use.
Re: Same DEXOS approval number for several brands? [Re: 21Rouge] #5183777 08/10/19 04:30 PM
G
Garak Offline
G
I wonder how that works. I'm not exactly sure how an A3/B4 can be dexos2 (or dexos1, for that matter).
Re: Same DEXOS approval number for several brands? [Re: 21Rouge] #5183814 08/10/19 05:36 PM
Direct_Rejection Offline
[Linked Image]
Look carefully everyone.
It says "Dexos Gen 2." What appears to be a "2" is actually just the Dexos logo color coded green for dexos1.
The dexos2 logo would be in blue, not green and has a smaller 2, easy to delineate, and in the lower right hand corner.
2019 Lexus UX 250h F-Sport
TGMO 0W16
@ 34k miles
Re: Same DEXOS approval number for several brands? [Re: RyanY] #5183819 08/10/19 05:47 PM
Wait.
What the heck is going on here ?
I knew there was something wrong with this picture.
So, this oil is purportedly...
a 0W30 motor oil
dexos1 gen2
A3/B4
SL
Huh ?
I just went to the Castrol website and looked.
Strange.
Impossible.
TGMO 0W16
@ 34k miles
Re: Same DEXOS approval number for several brands? [Re: Direct_Rejection] #5183844 08/10/19 06:32 PM
G
Garak Offline
G
Exactly. Something is amiss here. A dexos1 oil must be a GF-5 type oil, which this is not. A dexos2 oil requires a lower SA, which this lacks.
Page 2 of 4 1 2 3 4
